vehicle trailer hitch wiring kit.
				maxpowers
Hey guys just looking for suggestions, on favorite brands.
Was just going to go to cambodian tire and grab one, but thought i would ask to see if some are easier to install or higher quality etc, cheers.
session the gnar
				Pajero
- Vehicle: 94 Pajero
Re: vehicle trailer hitch wiring kit.
I just bought mine from princess auto, they have alot of trailer hitch wiring kits there for less than canadian tire
Whatever model/brand you get, get one that is powered, don't get the kind that simply leech a signal from the turn signals. When the unit fails (and they invariably do), those kind will drag down you whole electric system, producing all sorts of weird and wacky faults. The powered ones, when they die (and they tend to last WAAAAAAAAYYYYYY longer than the crappy kind), they just die and don't affect the remainder of the circuit which they were tied into.
- Firesong
Do Not get one from CT
I had bothing but problems with two of theirs.
Worked for a while then i started getting lighting issues.
The vans lights, tail lights etc would do weird things
Its documented here somewhere
The ones from princess auto have worked fine
Im sure there are others but dont use them from ct
FS
FS
				maxpowers
is it a 4 way or a five way I need, further research has left me confused? I just read a post on here about a 4->5 way adapter or something?
							session the gnar
Don't get one of these: http://www.princessauto.com/trailer/tra ... -converter
Instead, get something like this: http://www.thehitchstore.com/3-to-2-wir ... -1708.html
You need one that converts our three signal system (turn, brake, park) to a two signal system (turn/brake, park). And as I typed previously, get the powered one, not one that draws power only from the signal light.
				sfd_656
- Vehicle: l400
Our van came with wiring installed, is there an easy way to tell if it is "powered" or not?
If there's a fused wire going to the battery.sfd_656 wrote:Our van came with wiring installed, is there an easy way to tell if it is "powered" or not?
- Artacoma
- Vehicle: 97 V6 LWB
When I had my L300 I put a Crappy tire trailer harness in it and it took out my head lights and brake lights in short order.
Switched to a powered setup (from Lordco sorry no part no) and all was fine.
With a non powered setup my turn signal flasher flashed at double time because of the extra lights the system was trying to power.
Rik
97 Series 2 V6 LWB
						97 Series 2 V6 LWB
				92pajero
- Vehicle: 92 pajero exceed
Gentlemen,
I have been using the PA hookups for years and never had any issues with any of the vehicles that I installed them on including a 92 Shogun and a 92 LWB Pajero. You can dra from your lighting sysytem just install a fuse holder in line to each wire between the converter box and the vehicle wiring your tying into. Ya it sounds tedious but I have never had an issue and its a few bucks for peace of mind.
Kelly
Kelly
				maxpowers
hey, which green wire powers the tail lights and which one boosts the light for braking.
there is a green one with a white stripe and there is a solid green one, anyone know?
session the gnar
