Glow plugs: oily and broken
lost2
Vehicle: Delica L300 Exceed 1990 4wd RHD
Post by lost2 »
Hi there,
Yesterday I ordered new glow plugs.
When taking off the old ones, I found that one had some oil on it and another one had his tip broken. Are these signs of a worse problem ? Thanx for any advice,
Davy
L300 low roof 1990 4wd 3d56t
Manual glow plug cycle (plugs burned because of a bad use of the manual cycle in winter)
Rising Sun Auto Import
Re: Glow plugs: oily and broken
It is very usual and natural as long as you have a manual control system.
you can't start engine at the optimum temperature , which is leading short life and misuse. :-(
Steven
Have a compression and leakdown test done when you can.
Tips that have burned off and drop into the piston chamber can have a negative effect on the engine's lifespan.
lost2
Post by lost2 »
jfarsang wrote:Have a compression and leakdown test done when you can.
Thanks for the advice. I've seen my mechanic yesterday but he is not much into diesel, so i'll have to find someone who has the proper tools to do these tests. I let you know about the results eventually.
