Need Help With Vacuum line identification !!
dan_sando88
Vehicle: L300 Exceed
Post by dan_sando88 »
Hi from Australia everyone! been on the site a year or so but only recently started doing some work on the Del.
I ran into a few problems a while back and have been doing some engine work and found that I have broken this thing
from what I have read its something to do with controlling the throttle when the ac is switched on, is this correct? thing is I can't find a replacement and i have gutted my car of the a/c system so I was wondering if I could remove this completely and just block both vac lines that run to it?
my other question is regarding the loom it plugs into... from what I can see it seems completely a/c related however I have followed it up under the dash and it splits up. Is this loom just for the a/c and if so can I remove it if I have no air con anymore??
thanks
Dan,
legionnair
Vehicle: delica L300
Re: Need Help With Vacuum line identification !!
Post by legionnair »
Could you drill it a bit bigger and epoxy a copper tube in its place?
mdrive
Post by mdrive »
AS FAR AS I KNOW IT IS FOR IDLE TO GO UP WHEN YOU TURN ON THE AC. YOU WILL STILL HAVE AC IF YOU REMOVE IT, BUT YOUR IDLE HAS TO RAISE UP A BIT.
dan_sando88
I pulled the a/c out a while ago though so it shouldn't matter I just wanted to mAke sure it wasn't important for anything else
