96 mitsubishi Delica L400 Diesel SWB auto, On HOLD
MardyDelica
Post by MardyDelica »
1996 L400 Delica Spacegear 2.8L intercooler turbo Diesel, 4m40 engine, Auto, 4x4, Exceed model,
Kms;105,000 kms
Its a grade 3.5 which is good
Has Crystal roof on this, hard to find a nice White color L400
Things will do to this lovely nice Crystal roof SWB
install brand new 4 tire Yokohama (ATS) all terrain tread pattern mud & snow,no charge for the cost of this.
we dont put all season tire on all our L400 as its not good.
install new led day time running light, only take 2 watts on your battery energy,
we dont hook up direct to the headlight system thru
combination switch as soon will have big problem it will burn the complete headlight module, has full voltage,
not compatible hocking it up to the headlight switch System as its burns the combination switch.
install new block heater
4 new pro comp 9000 series shock heavy duty one
brand new front & rear brake pads= if needed
machine front & rear rotors,
re-pack front hub both side if needed
new front stabilzer link if needed
new e-code headlight with led DRL headlight= new
New transmission Filter & fluids= new
new oil & all fluids,
new front & rear reflector
brand new L400 antifreeze water bottle original not china
new water pump
new thermosthat
All new fan belt 3 pcs
replace new front injection pump seal= no additional charge
Clean & pre set the 4 injector= no additional charge its included
New valve cover gasket
Do adjust TPS sensor timing to have a proper & smooth shifting of your L400 will runs like a car
so buyer beware. thru us we only sell mostly fully service vehicle to give full customer satisfaction &
its a must to see before buying this type of delica for you & your family
we offer the best possible price for your budget with full service on this Delica
For your inquiry pls feel free to contact me, will more than happy to answer all your question.
This L400 comes with 1 year or 12,000 kms on power train warantty whichever comes first
Include one month full warranty including brakes, electrical, suspension and other issue that might occur
as this is a used car. thru my shop in Richmond.
DO FULL COMPLETE WARRANTY WIHTOUT CHARGE WITH IN A MONTH OF YOUR PURCHASE THRU AMAZING AUTO IMPORTS LTD.
this is the kind of service we offer here for this car and all of the car we sell:
This lovely swb low roof will arrive next month JULY
Pls call
Arrived On HOLD
Stock # PE8W=105K White
Amazing Auto Imports LTD
Any questions please call me:
604-247-2111 / 604-720-6144
thanks,
MardyDelica
Re: 96 mitsubishi Delica L400 Diesel SWB auto pls call
more pictures:
MardyDelica
Re: 96 mitsubishi Delica L400 Diesel SWB auto,pls call
more pictures:
MardyDelica
Re: 96 mitsubishi Delica L400 Diesel SWB auto, On HOLD
Arrived On HOLD now
Thank you
