symptoms:
1. when my AC is on, my RPMs drop about a hundred.
2. when i turn off my AC my RPMs raise about a hundred.
(i thought it was supposed to be the other way around; higher RPMs with AC on...
3. yesterday i noticed that my RPMs increase slightly with the headlights turned off. i turn them on, and the RPMs drop slightly. my headlights are not dim at all(they are fine), and i'm not getting any kind of dash indication that something is wrong...
today i turned off everything "extra". no radio, no AC, no lights, etc. the van seems to idle a bit high (900) after a long hill, the van runs at normal temperatures.
are my headlights and AC too hard on my battery/charging system or something? i have a 6 light voltmeter/indicator, and it tells me everything is ok. other than an MP3 player adapter, and a ham radio, i don't have aything else drawing power while i drive.
i thought maybe the alternator brushes were getting worn.
should i be planning for an alternator or battery overhaul?
