nasty oil leak need new seals
sebastian
I have a nasty oil leak coming from the front of the engine. I had a mechanic who owns a landcruiser take a look at it and he told me I needed new cam and crank seals any idea where I could get them? thank you very much for your help
best van ever!
- MardyDelica
Re: nasty oil leak need new seals
I can supply you for that made in japan seals, you need 4 seals,camshaft,crankshaft, oil pump seal, & tensioner seal
you can e-mail me or phone me 604-720-6144
- ccautos
- Vehicle: 92 Delica SE
All seals except lower balance shaft seal are available off the shelf at Lordco or Napa . Cam seal is #13907 upper balance is #9706 , sold the last of my crank seals and didn`t write the number down !! I will post it when I have it crossed again
