1995 L400 LWB Delica Spacegear 2.8L intercooler turbo Diesel, 4m40 engine, Auto, 4x4, Super Exceed model, has 151,000 kms. its a winter package L400, double battery
This L400 is hard to find now a days
Mileage is in fair mileage not to high for a 16 year old car
This LWB L400 has Turbo timer attached on it, its a bonus for this L400
Has front sunroof and rear crystal roof
has a complete curtain on it which is a plus
Things will do to this lovely nice LWB L400
install brand new 4 tire Yokohama (ATS) all terrain tread pattern mud & snow
no charge for the cost of this.
we dont put all season tire on all our L400 as its no good.only good yokohama tire
install new led day time running light, only take 2 watts on your battery energy,
we dont hook up direct to the headlight system thru
combination swtich as soon will have big problem it will burn the complete headlight module, has full voltage,
not compatible hocking it up to the headlight switch System as its burns the combination switch.
install new block heater
4 new pro comp 9000 series shock heavy duty one= a must to change
brand new front & rear brake pads= if needed
machine front & rear rotors= if needed
re-pack front hub both side if needed
new front stabilzer link if needed
new e-code headlight with led DRL headlight= new
New transmission Filter & fluids= new
new oil & all fluids,
new front & rear reflector
brand new L400 antifreeze water bottle original not china
new water pump
new thermosthat
All new fan belt 3 pcs
replace new front injection pump seal= no additional charge
Clean & pre set the 4 injector= no additional charge its included
New valve cover gasket
Do adjust TPS sensor timing to have a proper & smooth shifting of your L400 will runs like a car
will also install a newly conversion glow plug bas bar & cable to ensure to have a proper volts to each glow plug.
thru us we only sell mostly fully service vehicle to give full customer satisfaction &
its a must to see before buying this type of delica for you & your family
we offer the best possible price for your budget with full service on this Delica
For your inquiry pls feel free to contact me, will more than happy to answer all your question.
This L400 comes with 1 year or 12,000 kms on power train warantty whichever comes first
Include one month full warranty including brakes, electrical, suspension and other issue that might occur
as this is a used car. thru my shop in Richmond.
DO FULL COMPLETE WARRANTY WIHTOUT CHARGE WITH IN A MONTH OF YOUR PURCHASE THRU AMAZING AUTO IMPORTS LTD.
this is the kind of service we offer here for this car and all of the car we sell:
This lovely LWB will arrive next month AUG
Price:
$11,500
Stock # PF8W=151K Green
Amazing Auto Imports LTD
Any questions please call me:
604-247-2111 / 604-720-6144
thanks,
95 Mitsubishi Delica L400 LWB Diesel,Auto $11,500 In transit
- MardyDelica
- DSCN3989.JPG (91.6 KiB) Viewed 3449 times
- DSCN3992.JPG (86.74 KiB) Viewed 3449 times
- DSCN3991.JPG (57.86 KiB) Viewed 3449 times
- DSCN3998.JPG (88.36 KiB) Viewed 3449 times
- DSCN3999.JPG (70.36 KiB) Viewed 3449 times
- DSCN3997.JPG (89.32 KiB) Viewed 3449 times
- MardyDelica
Re: 95 Mitsubishi Delica L400 T-Diesel,Auto $11,500 In tran
more pictures;
- DSCN4007.JPG (78.77 KiB) Viewed 3448 times
- DSCN4004.JPG (83.72 KiB) Viewed 3448 times
- DSCN4002.JPG (83.43 KiB) Viewed 3448 times
- DSCN4001.JPG (74.68 KiB) Viewed 3448 times
- DSCN3994.JPG (91.23 KiB) Viewed 3448 times
- MardyDelica
More pictures;
- DSCN4009.JPG (87.25 KiB) Viewed 3448 times
- DSCN4021.JPG (91.31 KiB) Viewed 3448 times
- DSCN4020.JPG (90.62 KiB) Viewed 3448 times
- DSCN4019.JPG (88.33 KiB) Viewed 3448 times
- DSCN4015.JPG (75.22 KiB) Viewed 3448 times
- DSCN4016.JPG (83.62 KiB) Viewed 3448 times
