1996 L400 Jasper_SOLD
Rising Sun Auto Import
We have another L400 Jasper coming in July.
**June/1996, Jasper high roof, ladder, 2800cc turbo diesel, automatic, 125K, original rims, ps, pw, airbag, winter package, green 2 tone color, grading4.
Price ; $11,400
We are accepting hold deposit. Ask for details.
Here are lists we check/replace for our stock delicas.
1. Engine componenets
** IP front seal replacement, valve adjustment, timing chain tension/loose adjustment, make sure no oil leaks( in case of L300, new timing belt/balancer belt/tensioners, 4 front oil seals replaced )
2. Transmission/4WD fuction
** If anything wrong, we replace sensor/switch, etc
3. steering/suspension/axle
** repack hub, and replace bearing if worn, all bushings/ball joints/CV boots/rack & pinion boot /links replaced if needed, wheel alignment, etc.
4. brake system
** flushing fluids, rotor machined or replaced, replace brake pads under 60% depth, all caliper checked
5. cooling system
** new radiator, new water pump, new thermostat, new hoses, new expansion bottle if needed.
** new temp guage/switch if needed
6. starting
** new battery if needed, new Hyundai 11V glow plugs ( best in Canada ), check glow plug relay/wiring, alternator/starter checked, make sure initial idle good.
7. interior
** make sure no broken parts, all power groups are working
8. exterior
** We focus on importing clean/good shape cars, no worry.
9. all fluids replaced ( engine oil, coolant, transmission oil, transfer case oil, front/rear differential oil ), new air filter/new fuel filter,all new V-belt, a/c checked and refilled.
10. compliance
** new tires Yokohama Geolandar A/T-S ( upgrade available with extra cost ), new e-coded headlight, DRL, marker/reflectors
11. canadian version CD player/stereo
** it is not included in our listing price.
12. block heater, trailer hitch
** installation extra
We might have missed some lists we usually do , but we are very proud of our job.
For more in transit delica info, visit our website.
http://www.rs-import.ca/shop/step_subma ... 0723014349
Steven 778-995-2459
David 778-237-4602
or shop 604-544-5120
1 (2).JPG (110.65 KiB) Viewed 4409 times
1 (1).JPG (122.84 KiB) Viewed 4409 times
1 (3).JPG (120.55 KiB) Viewed 4409 times
Last edited by Rising Sun Auto Import on Sat Aug 06, 2011 8:10 pm, edited 5 times in total.
Re: 1996 L400 Jasper 125K in transit ( July )
This L400 arrived at Fraser Wharves, applied for a soil inspection 3 days ago.
We expect to pick it up early next week. :-)
All our stock ( including in transit ) delicas are on sale now.
http://www.delica.ca/forum/no-hst-summe ... 11213.html
We are planning to initiate financing program for all our stock soon.
Steven 778-995-2459
Re: 1996 L400 Jasper 125K_arrived
We picked up this nice L400 from the Port this morning.
Started compliance and servicing now.
Contact us if you have any inquiry. 8-)
Steven & David
604-544-5120
** good/clean Delicas with affordable price/perfect maintenance into Canada**
Re: 1996 L400 Jasper 125K_compliance & servicing
This 1996 L400 Jasper is ON HOLD to Sunshine Coast. 8-)
Steven & David
604-544-5120, 778-995-2459
Re: 1996 L400 Jasper_compliance & servicing_SOLD
This nice L400 Jasper has been sold to Mr. Kyba at Sunshine Coast.
We fix all power group issue before selling, even certain period after sales.
** sunshade, sunroof, power window, power door lock, sliding door, etc.. except front headlight washer function :-D
We definitely bring all posting Delicas into Canada as fast as possible ( usually 6-7 weeks after buying ), whether they are hold by customers here in Canada or not.
For more stock/transit info, pls visit new delica trader or our website.
http://www.delica.ca/trader/customlist/2
http://www.rs-import.ca/index.php
Steven 604-544-5120, 778-995-2459
