96 Mitsubishi L400 T-Diesel Jasper Airbag Auto 74k *SOLD*
MardyDelica
Post by MardyDelica »
1995 L400 Delica Exceed Spacegear SWB 2.8L intercooler turbo Diesel, 4m40 engine, Auto, 4x4, Jasper model,
jasper green color, L400, has 74,000 kms. has dual winter package battery
8 Passenger SWB L400 Spacegear
has low mileage jasper hard to find
No Rust at all as you can see thru the rear ends,
its a clean L400 Spacegear
Things will do to this lovely nice Jasper L400:
install brand new 4 tire yokohama
install new block heater
4 new pro comp 9000 series shock heavy duty one
brand new front & rear brake pads ( made in Japan pads)
machine front & rear rotors,
repack front hub both side
new front stabilzer link
new e-code headlight with led DRL headlight
New transmission Filter & fluids
new oil change & all fluids has been change front to rear
new front & rear reflector
brand new L400 antifreeze water bottle
new water pump
new thermosthat
All new fan belt 3 pcs
replace new front injection pump seal
Clean & pre set the 4 injector
New valve cover gasket
will pre- set TPS sensor timing to have a proper & smooth shifting of your L400 that will runs like a car
This service will cost you high, if you send it for service, i see other L400 without any service. seen for few month now that many L400 sold by other , but dont even service there vehicle.
so buyer beware. thru us we only sell mostly fully service vehicle to give full customer satisfaction &
its a must to see before buying this type of delica for you & your family
we offer the best possible price for your budget with full service on this Delica
if any question pls feel free to contact me, will more than happy to answer all your question.
This L400 comes with 1 year or 12,000 kms power train warrantty whichever comes first
SOLD
Stock # PE8W- Jasper 74K
for inquiry pls contact:
Amazing Auto Imports Ltd
604-247-2111 / 604-720-6144
Thank you,
MardyDelica
Re: 96 Mitsubishi delica L400 T-Diesel Jasper Auto 74k *Arri
This 1996 delica L400 Jasper is in good condition with air bag on it
low mileage with full service not partial service with lube change only.
will cost you more money without service on this delica.
for inquiry pls call me anytime:
Cheers;
MardyDelica
Re: 96 Mitsubishi L400 T-Diesel Jasper Airbag Auto 74k *ON H
Hi, This Nice delica L400 is on HOLD
thank you
MardyDelica
Re: 96 Mitsubishi L400 T-Diesel Jasper Airbag Auto 74k *SOLD
Hi, This Delica is SOLD
thank you
