92 Mitsubishi L300 Low roof 5 Spd 74k mint on *SOLD*
- MardyDelica
1992 Mitsubishi Delica L300 'Exceed' Edition very low mileage No rust
Grade 4
Has upgraded stainless muffler 2 1/2 inch size worth $from original from japan
this will make this L300 runs much better more torque & power as you got bigger exhaust
2.5L turbo Diesel, 4D56T engine, 4x4, 74Km.5 Spd, Low roof, A/C. 7 passenger, fully loaded
Always park on coverded parking good condition even the paint is good.
under no rust, Trubo no leak runs good. injection pump no leak
Non smoker seat looks like new
with rear ladder worth $300
After market aluminum wheel special design
Recent work :
LED day time running light , so no more of having problem with the headlight switch. more reliable.
Full Tune up
New Timing belt
Belts
Water pump
New thermosthat
New tires
New engine seals, Crankshaft, camsahft, oil pump & balance shaft seal all new
Delica-tune= Clean injector
Good brakes
Front hubs repacked
All fluids have been changed
New Fuel filter
New valve cover gasket
Rear end new gear oil
Change All front stabilizer bushing
Adjust intake & exhaust valve
Start and runs very strong.
Depo LHD headlights with E-Code on it
On HOLD
Stock no. P25W-74k
Pls call me if need to view the vehicle ready to go:
604-247-2111 / 604-720-6144
Cheers:
Grade 4
Recent work :
Full Tune up
New Timing belt
Belts
Water pump
New thermosthat
New tires
Good brakes
Front hubs repacked
New Fuel filter
On HOLD
Stock no. P25W-74k
Cheers:
- DSCF2080.JPG (77.19 KiB) Viewed 10725 times
- DSCF2079.JPG (51.44 KiB) Viewed 10725 times
- DSCF2078.JPG (55.88 KiB) Viewed 10725 times
- DSCF2076.JPG (58.71 KiB) Viewed 10725 times
- DSCF2074.JPG (74.96 KiB) Viewed 10725 times
- DSCF2073.JPG (73.65 KiB) Viewed 10725 times
- MardyDelica
Re: 92 Mitsubishi L300 Low roof 5 Spd 74k mint cond $9,000
more pictures;
- DSCF2082.JPG (73.64 KiB) Viewed 10721 times
- DSCF2081.JPG (76.16 KiB) Viewed 10721 times
- DSCF2083.JPG (57.89 KiB) Viewed 10721 times
- DSCF2084.JPG (71.62 KiB) Viewed 10721 times
- DSCF2087.JPG (76.05 KiB) Viewed 10721 times
- DSCF2088.JPG (55.97 KiB) Viewed 10721 times
ottawa_boy
- Vehicle: Mitsubishi-Delica
Re: 92 Mitsubishi L300 Low roof 5 Spd 74k mint cond $9T arri
Hi Mardy,
Is this still available?
- MardyDelica
yes, its still available.
good nice L300 manual 5 spd. no rust almost new, inside is absolutely clean
hard to find like this anymore and lots of goodies
call me pls if you need this 604-247-2111/ 604-720-6144
Cheers;
Cheers;
- MardyDelica
This L300 is in mint condition almsot like new non smoker vehicle.
seat no tear & no cigar burn
available anytime now
cheer;s
mardy
cheer;s
mardy
- MardyDelica
dfcp13
- Vehicle: L300 low roof 5spd!!!
Hey Mardy, is the middle row a bench or captain chairs?
Thanks.\
Never mind 7 seater.
Thanks.\
- MardyDelica
Hi, its a 7 passenger low mileage mint.
under like new not 18 years old
nice to buy never been in a snow place
cheers;
mardy
cheers;
mardy
- DSCN2927.JPG (90.81 KiB) Viewed 10218 times
- DSCN2930.JPG (83.6 KiB) Viewed 10218 times
- DSCN2926.JPG (86.65 KiB) Viewed 10218 times
- bdowie
- Vehicle: 95 L400 5speed CLR Spacegear
Is this still available? I didn't see it on your website.
- MardyDelica
yes, still available
sorry just don thave time to put it in in my web site cheers;
- bdowie
Do you have any other 5 spd in stock? Does this one have a sunroof?
- MardyDelica
hi, this nice L300 is on HOLD
thank you very much
Cheers;
thank you very much
Cheers;
- bdowie
Guess I am too late on that one.
- MardyDelica
Re: 92 Mitsubishi L300 Low roof 5 Spd 74k mint on HOLD
ah yes,
pls pm me maybe i can get you one for you
cheers;
cheers;
- MardyDelica
Re: 92 Mitsubishi L300 Low roof 5 Spd 74k mint on *SOLD*
Hi,this Nice L300 is SOLD
thank you very much David,
enjoy your new ride;
Cheers;
Cheers;
