95 Mitsubishi Delica L400 SWB T-Diesel Auto *SOLD*
- MardyDelica
1995 L400 Delica Spacegear 2.8L intercooler turbo Diesel, 4m40 engine, Auto, 4x4, Super Exceed model, Winter package With Dual battery Silver color, L400, has 124,000 kms.
This L400 Silver SWB is hard to find now a days
Things will do to this lovely nice white Super exceed L400 LWB:
install brand new 4 tire Yokohama all terrain tread pattern mud & snow
install new block heater
4 new pro comp 9000 series shock heavy duty one
brand new front & rear brake pads ( made in Japan pads)
machine front & rear rotors,
re-pack front hub both side
new front stabilzer link
new e-code headlight with led DRL headlight
No rust
New transmission Filter & fluids
new oil change & all fluids has been change front to rear
new front & rear reflector
brand new L400 antifreeze water bottle
new water pump
new thermosthat
All new fan belt 3 pcs
replace new front injection pump seal
Clean & pre set the 4 injector
New valve cover gasket
Do adjust TPS sensor timing to have a proper & smooth shifting of your L400 will runs like a car
will also install a newly conversion glow plug bas bar & cable to ensure to have a proper volts to each glow plug.
the old one or original one sometime dont give correct full voltage need the glow plug to heat it up when need to start this L400 when the weather is cold.
now it been tested to my other L400 & it works really good mostly when it in a cold early morning.
we try to improved the glow plug issue for this L400 when its reach a very cold weather & we prove it now that it works very good. its a big help when we install this.
so buyer beware. thru us we only sell mostly fully service vehicle to give full customer satisfaction &
its a must to see before buying this type of delica for you & your family
Its a Christmas sale for our fellow delica owner
we offer the best possible price for your budget with full service on this Delica
For your inquiry pls feel free to contact me, will more than happy to answer all your question.
This L400 comes with 1 year or 12,000 kms power train warrantty whichever comes first
SOLD
Stock # PE8W= Silver124K
Amazing Auto Imports LTD
Any questions please call me:
604-247-2111 / 604-720-6144
thanks,
No rust
new water pump
new thermosthat
SOLD
thanks,
- silver pe8w (2).jpg (52.76 KiB) Viewed 6052 times
- silver pe8w.jpg (51.83 KiB) Viewed 6052 times
						- MardyDelica
Re: 95 Mitsubishi Delica L400 SWB T-Diesel Auto 124K *ON HOL
This Delica L400 is oN HOLD
Thank you
						Thank you
				NorthernOntario
 - Vehicle: 95 l400, 99 vw Beetle , 90 vw jetta
Is this Vehicle In Transit?
						- MardyDelica
yes, its already in schedule for when i came back next month
thank you
Cheers;
mardy
						thank you
Cheers;
mardy
				NorthernOntario
Will do
thank you !
						thank you !
- MardyDelica
- MardyDelica
- MardyDelica
Re: 95 Mitsubishi Delica L400 SWB T-Diesel Auto HOLD
Congrats Adam. It's a nice rig.
						- MardyDelica
Re: 95 Mitsubishi Delica L400 SWB T-Diesel Auto *SOLD*
Hi, this Nice L400 is SOLD
thank you very much Adam enjoy your new ride
Cheers;
Cheers;
