Price: 9,400.00
BC Inspection Completed. (New Tires, Headlight, DRL, Front Corner Light Added, High Mount Brake Light)
Servicing Included in the price with 1 year Power Train Warranty:
CleanedBattery Terminal with New Battery
Brake Pad Replaced
Rotors Machined
Front Wheel Bearing / HUB Re-Greased
Ball Joint Checked
Tie Rods / Steering Link Checked
Sway Bar Bushing Replaced
All Suspension Parts Regressed.
Shock Absorber Inspection Checked
Coolant Flushed
Engine Flushed
Oil Chevron Delo 400
Power Steering Fluid Flushed
Clutch Fluid Flushed
Brake Fluid Flushed
Gear Oil Chevron
Differential Oil Chevron
Transmission Fluid Chevron
Thermostat OK
Water pump chekced
Radiator Cap OK
Power Steering Belt OK
Alternator Belt OK
AC Belt OK
T-Belt Replaced
Air Filter Changed
Fuel Filter Changed
Oil Filter Changed
Change Muffler or Pipes OK
New Wipers Installed
All Hinges Greased
New CD/MP3 Player Installed
Complete Detailing Package (Interior, Exterior, Enigne)
