Awwwww Yeeaah!
Right on!
Not sure where you got this from? Any proof? You can air down a narrow tire as much as any other tire. Unless you have a beadlock there is no difference.jcolvin wrote:One thing the author doesn't seem to consider is the fact that a wide tire can be aired down to a much lower psi than a narrow tire. For instance, a tire twice as wide can probably be aired down to 1/2 the psi of the narrower tire.
Sure, but how does your wide tire perform if the hole is even wider than your wide tirejcolvin wrote:Now there is no longer any mechanical advantage to the narrow tire. The wide tire has some advantages on rough roads; it is less likely to fall entirely into holes (imagine a rut/hole of slightly greater width than a narrow tire; the narrow tire will fall entirely into the rut and bang, whereas the wide tire will stay out of the hole by virtue of being wider.
I do the same with a narrow tire.jcolvin wrote:You can air them down dramatically and they soak up the bumps like a hovercraft.
