Big ol' post on keeping your diesel running cleanly...
Re: Big ol' post on keeping your diesel running cleanly...
Screen shot! That is a great post!
- CREGAN
WELL PLAYED!!!! Yes I yelled, and then I laughed. Looks like you caught everyones finer qualities perfectly.
On a side note: I got an $89 "professional" photograph in the mail today courtesy of the Edmonton Police Service today. I love entrapment and cash grabs. So consquently I have been yelling a lot today.
Craig
Craig
- Rising Sun Auto Import
hahaha!psilosin wrote:Fishtank: "You anti-gellin'?"
tonydca: "I'm anti-gellin' like a felon!"
nxski: "I'm so anti-gellin', I'm like Magellan!"
1994delicaman: "I can't stop anti-gellin'...it's so compellin'."
FalcoColumbarius: "My fortune teller was foretellin' that I'd spend this winter anti-gellin'."
MardyDelica: "OK man I'm tellin'...gellin' this no good. hope this helps man."
CREGAN: "I'M SO ANTI-GELLIN', I CAN'T STOP YELLIN"!!"
RisingSunAuto "You want to be anti-gellin'? Well I happen to be sellin'."
Jfarsang: "Vendors sellin' anti-gellin' on the forum? Something is smellin'!"
thedjjack: "When anti-gellin becomes a dictatorship, its time to start rebellin'."
I can't stop laughing.
Steven
- tonydca
Good point - I'm under the impression that the Howes was a cetane improver as well as a lubricant.Fishtank wrote:Jeez thanks Jessejfarsang wrote:Howes is one of many in the line up of diesel conditioners (counters sulfur and winter gelling) that the 2 stroke oil will not do., I am actually quite familiar with the Howes line of fuel conditioners
My question was more directed at why is he is adding an anti gelling additive to winter diesel that already has gelling inhibitors? And if the 2-stroke oil is taking care of the lubricity deficiencies, why waste money putting Howes in the tank? Save that for the Summer months.
To be honest, I started using the 2-stroke oil just to try it out, but the primary reason I'm running it now is that it seems to improve my winter MPG. I plan to stop using it once they return to summer diesel blend and just use Howes.
So I guess I view my "normal" fuel as pump diesel plus Howes, with 2-stroke oil added as well in the winter to improve my mileage.
I'm not quitting Howes only because I'm not completely sure what else it does; might be overkill to use it in addition to 2-stroke oil but the incremental cost of an oz. of Howes is not a real concern to me. I don't want to mess up the results I'm so far getting this winter.
Maybe my brain's gone soft like a melon - I'm just tellin'...
Okay, I bite.psilosin wrote: FalcoColumbarius: "My fortune teller was foretellin' that I'd spend this winter anti-gellin'."
- And you're right, despite, the bad spellin' ~
Howe's helps keep my baby groovin',
Sit tight, tonight, though the tide be swellin' ~
Now's the time an' my wagon's a movin'.
'Though one fears the lack of sulphur ~
"Though the miles begin to wane,
And the load be that much bulkier ~
The road ahead remains the same.
Fear not, nor bow my precious Astron ~
'Tis a cetane cradle thy mounts doth hold,
To carry yon thine illustrious falcon ~
Be steadfast for thy treads be bold.
Embrace the summit as with no mean feat ~
Thy fire burns pure with Howe's Diesel Treat.
- Fishtank
Tony, why don't you try running a few tanks without the Howes but with the 2-stroke. It would be a good experiment to see if the Howes really does help in the winter. The 2-stroke is well proven, maybe a slight boost from the Howes helps, maybe it hurts..... Let's find out.
- tonydca
I actually started out with using 2-stroke *instead* of the Howes:Fishtank wrote:Tony, why don't you try running a few tanks without the Howes but with the 2-stroke. It would be a good experiment to see if the Howes really does help in the winter. The 2-stroke is well proven, maybe a slight boost from the Howes helps, maybe it hurts..... Let's find out.
http://www.delica.ca/forum/i-need-your- ... 12046.html
I'm adding the Howes as well now because I don't know what other benefits it might provide (cetane enhancer, ???) and the incremental cost is negligible.
- minicarz
- Vehicle: Royal Exceed Delica
What an excellent executive summary.
Great post!
Great post!
- Fishtank
Have you noticed a difference in any way when you add the Howes vs. without?tonydca wrote:I actually started out with using 2-stroke *instead* of the Howes:Fishtank wrote:Tony, why don't you try running a few tanks without the Howes but with the 2-stroke. It would be a good experiment to see if the Howes really does help in the winter. The 2-stroke is well proven, maybe a slight boost from the Howes helps, maybe it hurts..... Let's find out.
As for cetane, I see this is only an issue if your engine is running rough and possible pre-detonation is occurring since the increase in cetane level increases the pressure needed to detonate the diesel.
Depending on which product you're using from Howes, it is also an anti gelling agent. But winter diesel is usually good down to the -30*C range before any gelling starts and only REALLY needs to be added below that. There is nothing wrong with adding it before that temperature as a preventative measure, but if most of your driving is in the Vancouver area, it may be overkill.
Don't get me wrong Tony, I'm not trying to get you to stop using it, just trying to determine if there is real benefit in doubling the dose per tank. I too do things that may not be necessary or overkill, just so I feel better about my due diligence. I'm more looking for information than a debate.
- tonydca
I hear ya. I saw no noticeable difference in MPG with Howes vs. without, and anything else it might be doing re: lubrication or whatever; I'm not sure I'd really notice a difference.
It's mostly a preventative maintenance kind of thing for me.
- Fishtank
I wouldn't be afraid to pull the Howes from the treatment if you didn't notice a difference, the 2-stroke is providing sufficient lubrication with the side benefit of improved MPG. My Dad drives logging & Hwy trucks and has for longer than I've been on this planet, he has tried almost every additive and in every temperature range that BC can throw at us. He swears by running 2-stroke as the additive of choice unless it gets REALLY cold and then he adds the Howes anti-gel. That's all I run now is the 2-stroke (or should I say my wife adds it since she stole my vantonydca wrote:I hear ya. I saw no noticeable difference in MPG with Howes vs. without, and anything else it might be doing re: lubrication or whatever; I'm not sure I'd really notice a difference.
- tonydca
Fishtank wrote:(or should I say my wife adds it since she stole my van).
- noooooo.jpg (10.25 KiB) Viewed 6948 times
- joedelica
- Vehicle: 95 Exceed XR The Sapporo Can
Bought a 945ml bottle of IPA and added approx. 750ml of the IPA today once the fuel gauge was on low.
Took it for a good drive to Horseshoe Bay and back to Main St. in North Van.
Filled up and added the usual 2 stroke and diesel additive
Engine sounds as if it may be idling smoother.
I will be gentle on this tank of gas and update my observations for all.
Thanks Tony,
Joe
Thanks Tony,
Joe
- shealy
- Vehicle: 92 Delica Exceed
Re:
Lordco.shealy wrote:Quick question for you guys: where can I get the "howes diesel conditioner/additive" a bunch of you have mentioned? Is this a can tire product? I've been running with the 2-stroke oil and have totally noticed a difference by the way, so thanks!
