Everybody has a different concept/attitude when doing the job.jfarsang wrote:There is a distinct difference between what 'can' be replaced and what 'needs' to be replaced.Rising Sun Auto Import wrote:If you miss replacing 07338B and 07338C ( in the diagram ), you have oil/fuel mix problem again.
Members need to know the fact.
Leading the readers to believe that unless those two parts are replaced you will have and oil/fuel mix problem again is not the best way to sell something.
The two o-ring viton seals the dealer subtly mentioned above and in the other thread where the dealer recommended to rebuild the entire injection pump(not even 2 days old - cross posting) is not related to the main shaft seal issue which is requires a simple replacement solution. If the two o-rings would be rubber and not viton, then the additional replacement can be warranted. But it is definitely not a factual necessity that will lead to problems.
one makes a vehicle perfect if it needs repair , whereas the others just make it run.
Nothing goes forever when it comes to auto parts and we are driving 15 year old delicas.
Steven
