camber adjustment
- lost1
camber adjustment
I have just replaced all 4 tires and had the wheels aligned but it looks like the camber of my front wheels are out. Has anyone adjusted this themselves? any advice?
- Breadman
- lost1
- Breadman
- lost1
several reasons...What's the reason for cranking up the torsion bars on the front?
1) looks, some people think the vehicle looks better or "more aggressive" with the torsion bars cranked.
2) tires, if you crank up the torsion bars there's more space between the axle and the fenders allowing you to fit larger tires (or snow chains)
3) approach angle, if offroading, when you crank up the torsion bars you'll have an easier time dealing with obstacles in front as you'll have a better approach angle
4) ground clearance (see number 3)
