Middle Seatbelts
- Vehicle: 91 Exceed
Middle Seatbelts
Anyone replace the middle seat belts (for the two captain's chairs)? I have 3 boys in car seats and the seat belts in the middle do not lock (ratchet-style). A friend who also has a deli had his daughter call to him from the floor... still in her car seat - the car seat just slid right off the captain chair!
- lost1
- Kuan
- Vehicle: 94' L400 SWB
Any luck finding a solution to the seatbelts??
I just bought a Delica and noticed the same thing with the belts. Pretty useless, even for an adult. I am talking about the lap belts here. There doesn't seem to be any stopping mechanism on any of them.
I have one son in a car seat and we have a baby due in March. Need to sort it out quick.
Anyone suggestions welcom.
Kuan
Kuan
- Jungle Jon
- Vehicle: Toyota Tacoma
Hi Kuan, and welcome to the site.
Here's what I did for my car seat install, once I discovered that the captain's chairs weren't suitable.
Note: this is what worked for me, and not to be construed as advice. If in doubt, consult a qualified engineer. [/end_disclaimer] :)
For daily use, I put the car seat in the middle of the rear bench, and used the locking clip that comes with the car seat to hold the belt from slipping. I found that reclining the seat back made clipping the seatbelt in easier, and when the seat was straightened up, the car seat was quite held in place very snug. For the over-the-seat anchor I took a length of 3/8" Spectra core rope (higher tensile strength than steel, used for climbing anchors/accessories, etc.) and looped it over the internal frame of the rear bench, on the bar that runs front to back. MAKE SURE YOU DON'T LOOP IT AROUND THE SEAT RELEASE BAR! The internal frame is not visible when looking at the back, and the rope would need to be fished through the spot where the upholstery meets the material on the underside of the bench seat to go over the frame. I used a double-fisherman's knot to join the ends, then clipped the anchor to the rope and tightened.
Another time, we were going on a camping trip and needed to fold up the rear bench to get extra space for gear. I ended up putting the car seat in the front passenger seat, using the locking clip to hold the belt from slipping. I drilled a hole in the back wall of the engine compartment (behind the battery) and installed the anchor kit that came with the car seat. I cut a small slit cut in the carpet let the anchor peek through so there is enough to clip to, but so it's not sticking out and catching on things.
Jon
Jon
- Jungle Jon
No worries Kuan,
I know what you mean, my boy loved being up front with me too. Got a few double takes from other drivers when they see a 2 year old where they would expect the driver to be. :lol:
Forgot to mention, I had read on MDOCUK about someone getting a cinch-up type seatbelt from the wreckers to replace the inertial locking types in the captains chairs. I had bought a replacement belt from AutoValue but never got around to putting it in yet.
Jon
PS. Checked out your site, amazing photos!
Jon
I took the covers off the belt clips and the mechanism will work (with inertia) - slight change in motion and it locks. So if you're testing the belt by yanking with a jerk, that won't lock it - the vehicle needs to change motion and it will lock up. Still... for the kids I use the rear bench and the front passenger. BTW great tip for the anchors - thanks!
- 39Ronin
Do you guys wanna check out HERE for initial details of a COMPLETE 'newer model' seat belt system that I have got for sale....
I'll get some photos up as soon as the kit is all out of the vehicle....
Regards,
Bruce.
Regards,
Bruce.
Re: Middle Seatbelts
This thread may be dead.....
But,
Has anyone managed to retrofit Shoulder/Lap belts? I have two lil'ens in boosters and none of my middle or back seats have shoulder belts. Does the 90 Delica Super Exceed even have the upper anchors or will I have to drill them (ugh)?
What solution have people been using?
David
But,
David
1990 Super Exceed
- torchard
Replaced middle lap belts
I think someone mentions that the holes are in the posts behind the panels.
I recently replaced the stock interia type lap belts with ratchet type retractable units. See them here http://wescoperformance.stores.yahoo.net/resebe.html
See my post here viewtopic.php?f=10&t=722&hilit=
BTW Westcoperformance also sells a six point seatbelt for kids which is intended to mount in the centre position of a bench seat. It has dual shoulder straps much like the belt set up on a childseat. See it at http://wescoperformance.stores.yahoo.net/am4point.html.
I may get this when the younger ankle-biter is out of his child seat.
--T
--T
