The drip is following the left side of the block down to the lower pulley as you can see. (this is sticking the head under the rad from front of truck) Where could this come from? I removed the intercooler and can't seem to find where it originates without taking a bunch of crap (everything) out.
I had a similar leak that ended up being a O-ring in the cold idle mechanism, but it was visible from the top as well, but that was a minor drip, this is loosing lots of fluid.
Sorry, learning as I go.. May be un-related.. but I found it odd that when I last changed the oil that the last quarter cup of oil to drain out seemed to be more watery, less thick than used oil.. Is this a sign of a cracked head? Wouldn't the water drain out before the oil due to sitting on the bottom? I have no other symptoms and runs perfect besides this leak. Coolant doesn't seem to have oil, but its hard to tell as it has had two different color of fluid.
Sorry for the long post, but Im getting fed up! THANKS!
(why is the max photo width so small? resizing sucks.)
 It was really hard to see as the coolant ran along the bottom of the hose in an area that you could not access and so I was looking in the wrong direction the whole time until I borrowed this tester from a local garage.  As my uncle who has been a diesel mechanic for 30+ yrs says, always look for the simple possibilities first.
