Parking lights are very low power. What you've seen is probably more like turn signal.DelicaMark wrote:On the topic of compliance if I change my DRLs from being my low beams to the white park lights on the front are there any issues? I have seen a park type of light used on other vehicles.
Green1 and I have done our DRLs as not-quite the parking lights. On the Delica, the parking light is a single filament bulb. We changed that for a dual "filament" 1057 LED, changed the base for a dual contact, and wired it so that as DRL the bright "turn signal" filament illuminates. When you turn your headlights on, it goes to the normal "parking" filament. We've also added relay so that applying the parking brake turns the DRL off.
Check Green1's posting at http://www.delica.ca/forum/drl-the-hard-way-1045.html for details and wiring diagram for his (mine is slightly different)
Get the brightest LEDs you can find. Mine are only about 9 LEDs and aren't that bright -- 200 metres away in daylight they are pretty much invisible. Going to have to do something about that. Not sure what, if anything, the law says about how bright the DRLs have to be, or what beam pattern.
I wouldn't recommend using incandescent bulbs for heat reasons. A turn signal is on only 1/2 the time, and usually only for short periods of time. Whereas DRLs can be on for hours at a time. Suspect that would melt the plastic housing. That's why we went with LEDs, but then you get the issue of they illuminate straight forward, and the reflector at the back of the light assembly does nothing.
I'm thinking of adding some small "driving" lights, mount them on the bull bar and add them to the circuit. That's because I want to be seen, more that worrying about compliance.
Another reason for not using the lowbeams is that, when some guy in front of you at night doesn't have his lights on, now you can flash your lights on/off. And the same when a truck passes you. If the DRLs are your lowbeams, you can't. (Had that issue on my Caprice with automatic headlights -- when dark it was impossible to turn off the headlights.)
Just my 2.5 cents (U.S., 2 cents Cdn)
"I could be just around the corner from heaven, or a mile from hell." -- Jackson Browne, "The road and the sky".
