Trouble shifting into 4WD C/D light flashing
mike_mitro@hotmail.com
Vehicle: Delica Super Exceed 2800
Post by mike_mitro@hotmail.com »
Tried to put L400 into 4wd and now C/D light is flashing and won't go off. The dashboard indicator never indicated all wheels engaged with 4 tires lite up green.
CREGAN
Re: Trouble shifting into 4WD C/D light flashing
Post by CREGAN »
Had a similar thing happen with mine and under some advice from Psilosin I took it out for about a half hour (slow)burn around the neighborhood cycling it through all of the ranges, back and forth and the light went away. Functions totally normal now and have not had an issue since. It also helped me to familiarize myself with shifting from 2-4wd on the fly.
Craig
CVI
Post by CVI »
Hi... trouble with the vac solenoid switch actuating the 4WD circuit. You may need to replace them to solve that issue.
MardyDelica
Post by MardyDelica »
it will be just a solinoid issue.
and your problem is gone.
if not some electrical issue would have come up
cheers;
Rising Sun Auto Import
Return to “L400 Technical”
