Broke my Drivers Seat - Stripped bolts! Where to find more?
Mr. Flibble
Post by Mr. Flibble »
So, I removed my drivers seat today to replace the heated seat elements (directions to follow in the other thread) when I finished, I brought my seat back out and began to tighten the bolts. Much to my dismay, I found that two of the bolts stripped! So, now I can't safely drive my Delica!
(I am going to try stealing 2 bolts from the passengers seat as a temp fix).
I went to Home Depot, and they had nothing. Does Mitsubishi proper have bolts for the Montero that would work? Is there a real risk that I need to get the holes re-threaded now?
Rising Sun Auto Import
Re: Broke my Drivers Seat - Stripped bolts! Where to find mo
Mr. Flibble wrote:So, I removed my drivers seat today to replace the heated seat elements (directions to follow in the other thread) when I finished, I brought my seat back out and began to tighten the bolts. Much to my dismay, I found that two of the bolts stripped! So, now I can't safely drive my Delica!
We would ship them to you if you need.
No charge of course.
Lordco has them in stock, for sure.
Steven
Last edited by Rising Sun Auto Import on Sat Dec 10, 2011 9:21 pm, edited 1 time in total.
nxski
Post by nxski »
I just re-tapped mine when it stripped and put in a bolt from home depot.
thedjjack
Vehicle: 1989 L300 HITOP!!
Post by thedjjack »
standard metric thread take a good one into any autoparts, motorcycle shop and they should have.
Luna-Sea
Post by Luna-Sea »
Canadian Tire has decent Metric fasteners,
if you are in Victoria there was and hopefully
still is a company called "Fastener Force Five"
that kicks supreme ass at coming up with
metric stuff.
http://www.yellowpages.ca/bus/British-C ... 64635.html
Still free and delivered is better.
Right On! 8-)
Mr. Flibble
Luna-Sea wrote:Canadian Tire has decent Metric fasteners,
metric stuff.
Right On! 8-)
Currently in Washington! :/
CREGAN
Post by CREGAN »
I got mine at a Honda shop. They have all the strange ones.
Craig
Mr. Flibble wrote: Currently in Washington! :/
Try Auto Zone or NAPA.
They should have them in stock.
Steven :M
Mr. Flibble
Steven :M
Thanks. Just stole the identical bolts from the rails of the middle seats, since I don't need anyone to sit in there. Guess I should also invest in a tap and die set as well.
