psilosin
Vehicle: L400
Re: What did you do to your Delica today?
Post by psilosin »
Over the weekend while paint was drying or thinset was setting I managed to steal some time to keep poking around the L400.
Hooked up teh charger again and gave it another go at recharging the batteries. They seem to be holding their charge this time and the rapid mystery drain disapeared for the time being...very strange considering I didn't do anything...
With the batteries working again I also decided to swap in another relay in my glow system and remove teh dead factory glow relay (to try and rebuild later) and some of its wiring. Discovered that even if not using the factory glow system to fire the glow plugs, if you remove the factory 80 amp glow fuse (and/or disconnect the factory glow wire that goes from fuse to ecu) that the starter will not spin. What that means is even if installing a completely seperate glow system from factory like I did, you still need the factory Glow ECU to be hooked up and functioning to be able to start the vehicle. Also discovered that the fuse is brittle as hell after 15 years...simply tugging on it with my powerful vice like arthritic fingers shattered the plastic into bits (luckily the fuse is a $4 part at Napa).
Anyway much to the disapointment of the Surf I kept the insurance on the L400 and am giving it another chance. It ran well yesterday and today so just hoping that the mystery battery drain doesn't reappear at work...because getting stuck at work is the suck. :-)
R.Costa
Vehicle: 1990 Mitsubishi Vanwagon
Post by R.Costa »
I put on my Mitsumaple sticker I received in the mail today. Thanks Mark!Image
Way cool.
R.Costa
Post by R.Costa »
Thanks Falco!!
LeeHammy
Post by LeeHammy »
Installed my JAOS mud flaps, PIAA winter wipers and an oil pan heater for those cold winter mornings.
i like cheese
R.Costa
Post by R.Costa »
Cool! I put on winter wipers too!!
1994delicaman
Vehicle: KTM
Post by 1994delicaman »
today I put on new chrome door trims
2006 smart car diesel CDI
2011 KTM 990 Adventure
2015 Mercedes GLK250 Bluetec
2018 KTM Superduke 1290 R
mdwyer
Vehicle: 1992 Delica Exceed
Post by mdwyer »
Just got my L300 back from CVI Automotive ...all I can say is WOW and thanks Butch Stephanie and company ..... lots of work done but the results are amazing its like driving a new vehicle ... :-D
Mike
I just switched in a new thermostat. Man are my wrists sore! I took her up the Cut and the temp needle hardly moved, although it was cold out tonight ~ but still, this morning when I climbed a big long hill the needle climbed and it was cold then, too.
Tojo
Post by Tojo »
Front diff fluid, it was disgustingly dirty, maybe hasn't been done in a couple of years
Rear diff fluid, it was amber and newer looking, maybe done recently by the PO
Tranny flush...just 2 litres, so I need to do it a bunch more times!
I just did a coolant flush today, switched in a new air cleaner element. I looked at the old thermostat today, now that it's dried off, I can really see the stain pattern left by the lime/calcium. If that is just the thermostat then I wonder how that works with rest of the system. I think it's good to flush every once in a while.
Shaun Van Ramen
Vehicle: '91 Exceed
Post by Shaun Van Ramen »
Burlap coffee bags...
I mean curtains!!!
BAHahahahahahaha
Tojo
Post by Tojo »
Dropped the deli off at Muffler-tech. Full end to end stainless from the flange back, 2.25" opening immediately to 2.5" with an 18" Flo-pro ending in a "squarish" tip, crazy bends around my trailer hitch and spare tire...but this is gonna hurt the wallet, I can feel the pain already!
solanoid
Vehicle: 95 deli SE- aka Rolls Rice
Post by solanoid »
No roof rack?
No problem! :-D
Fishtank
Post by Fishtank »
solanoid wrote:No roof rack?
No problem! :-D
:-D :-D :-D :-D Nicely done solanoid, true Albertan ingenuity with a hint of redneck mixed in. Two thumbs way up. 8-) :M
