Headlight Sprayers stay on
pajerochris
Vehicle: 94 Mitsubishi Pajero SWB
Post by pajerochris »
Hey guys, it seems as though my headlight sprayer switch is faulty. My headlight sprayers lately activate right when i turn headlights on (even though the stalk button is out). do these ever spray automatically? does anyone know which fuse the sprayers are?
Any help is appreciated, TIA.
Chris' Green 94 Mitsubishi Pajero SWB
Features:
3.5L, Sunroof, JVC head unit, Hella Supertones, BFG A/T's, 35% tint around
Future Possibilities:
Bullbar/A-bar, rear-view camera, lift, 33's
mitsubill
Vehicle: 1994 Pajero V26wg
Re: Headlight Sprayers stay on
Post by mitsubill »
The headlight washers are activated when the headlights are turned on and the button pushed(at least that is the theory, of the four Paj at the meet last night three had headlight washers that did not work and the 4th Paj did not have washers) Sorry I can`t help with the fuses, your problem is unique, most don`t work and yours work when you don`t want them to :-D
Pajerist
Vehicle: 1993 Pajero 2.8L 5-speed LWB
Post by Pajerist »
Washers should be activated by button when headlights are on.
They worked fine on my first Pajero and on second too untill that meet up :-(
Very disappointed :?
my first Pajero.jpg (169.73 KiB) Viewed 6210 times
Fight for Right to drive from Right!
http://forum.import-era.com/index.php
http://www.ivoac.ca
maybe the contact inside the switch (stalk)
nice spray shot ! Love 'em when they are working.
92pajero
Vehicle: 92 pajero exceed
Post by 92pajero »
Switch stuck? Button may be out but contact is still making contact. You can spray contact cleaner into the end of the switch and it may loosen the contacts up. The spray is alcohol based and will not damage anything.
Let me know if it works
kelly
"Why are some peoples mouths in overdrive but their minds are in neutral"
thedjjack
Vehicle: 1989 L300 HITOP!!
Post by thedjjack »
first check the button
next I would see if they have a relay..if so it maybe stuck (new relay)
pajerry
Post by pajerry »
Im lucky, mine have always worked great. Until the passenger side nozzle broke off somehow wheeling. Now it looks like a breaching whale when I turn them on. I can almost spray right into the convertibles beside me..
92pajero
Post by 92pajero »
I have a spare spryer assembly from my 92 pajero. Let me know if you need it, we can discuss bargaining later
pajerochris
Thanks for the ideas guys! I'm going to try to get to it this weekend. Im hoping it's the relay or stalk and not a shorted wire in the fender somewhere
Features:
Return to “Pajero”
