Not sure what your dealer will do, but I would rather have a reconditioned one over a used one unless you will have a new one swapped in.
Options are always good.
The Dealer replace the heater core,that took them a full day.jfarsang wrote:It may be cheaper for you to have a rad shop simply pull the core and re-condition it. That's another option.
That's more like it.claude wrote:I am getting 11l. per 100km
This is the exact leak I currently have :( same photo even hahaclaude wrote:I just fund the leak. I am not mechanically oriented and have no clue what is this plastic container and how to fix the dripping.jfarsang wrote:your heater core/blower motor is there behind the glove box.
take the glove box out and check the hose going into the heater core.
Also check the bleed valve in the engine bay. It's above the injection pump along the firewall. It looks like a black hose with a nylon nut screwed in. turn the engine on, let it idle, put the heat to full blast with the blower at full and the undo the nut. coolant should start to flow out. when it does, close it and then check to see if it still leaks inside.
