ECONO Mode Mod:
One thing that might help save some fuel while you are toodling around town is to place a vented switchable VSV valve inline of the boost line connected to the Boost Compensator with the control switch in the cab.  Works like a hot damn on my Hilux Surf gaining up to an extra 100km/tank.  I have noticed that the boost on the L400 winds up very quick even with a feather foot so this mod might work even better on the L400 than it does on my Surf depending on the L400's boost ramp etc.  Since I have been tweaking my L400 for higher performance I will not be doing this mod but for some of you it might be worth it.
It works by simply blocking the boost to the boost compensator when the VSV is activated (switched to ECONO mode) thus preventing a ramping up of the fuel delivery (ie you are still boostin' but the engine isn't getting & using the usual extra fuel that comes long with being on boost).  Yes that does mean it will drive exactly like it has no turbo BUT, based on my Hilux Surf which has less power than an L400, around town it likely isn't thaaaat noticable.  On the highway it will be a dog so unless you like pain switch back to NORMAL mode for highway and hills.
If your L400 had ECS and you have replaced the shocks with non-ECS shocks then you already have a perfect in-cab switch to control the VSV.
It is important that the VSV has a vent on the side toward the boost compensator, otherwise it you were boosting and then switched to ecconomy mode that boost in the line would be trapped between the VSV and teh boost compensator leving the boost compensator thinking it is constantly under boost which would actually cause massive OVER fueling.  The vent lets the presure disapate preventing this situation.
A bonus feature is that if you are zooming along in NORMAL mode and realize your EGTs are dangerously high...hit the ECONO mode and the fuel is cut but the boost airflow remains and teh EGTs will apparently drop faster than they would by just letting off the throttle in NORMAL mode.  (This bonus is based on commentary from the Aussie Surf guys...never had to try it myself.  Also based on comments on ih8mud that some of teh cruiser guys increase boost but lower fuel delivery for lower running EGTs.)
Pics from my Surf installation won't be too helpful since it uses an electronic boost sensor rather than a mechanical diaphram for the boost compensator but here is teh VSV I used on my Hilux Surf for an example:
