Increasing turbo boost
ubernub
- Vehicle: Mitsubishi L300 2.5TD
Hello everyone!
I wanted to increase the turbo boost on my L300 2.5TD and found some instructions on how to do it.
I installed a boost gauge, and tested the stock pressure before adjusting. It turned out to be 0.6bar / 8.7psi, which is very low since factory boost is 12psi!
I tried to adjust it up by tighting up the wastegate rod screw, but im not gaining any more boost.
What am i doing wrong?
Re: Increasing turbo boost
Factory boost is 8-9 psi.
11-12 psi is the max you want to push it in stock format.
ubernub
As im reading the manual with specs right now, I can tell you that you're wrong. It says that the wastegate should open at 11,9 PSI on the 4D56T engine.jfarsang wrote:Factory boost is 8-9 psi.
- wastegate.PNG (105.49 KiB) Viewed 8368 times
How many turns are you doing?
Boost don't go up if there is no more fuel.
ubernub
Could you explain how to increase the fuel flow? pics would be nice!tiitus wrote:Boost don't go up if there is no more fuel.
yojimbo
Most of the time though there is plenty of exhaust gas to keep increasing the boost, thats why you need a wastegate to vent it, you can prove it by pulling the pipe off and seeing how much boost you get.
1994 L300 Jasper
1986 Scimitar 1.8Ti
1986 Scimitar 1.8Ti
Loose that 13mm nut and turn (in) center bolt, first half round, then thigtenubernub wrote:
nut and try. If it's ok, you have more boost.
But don't get you boost too high, or you need a new engine.
ubernub
Thanks! there was a little brass cap on the adjustment screw, but it was easy to remove! It smokes a little black when i rev it, and when flooring it on low boost.. Black smoke doesnt harm anything on the engine? is it possible to damage anything if i turn it up to make a smoke machine? hahe!tiitus wrote:Loose that 13mm nut and turn (in) center bolt, first half round, then thigtenubernub wrote:
nut and try. If it's ok, you have more boost.![]()
But don't get you boost too high, or you need a new engine.![]()
The turbo boost is up to 0.8BAR / 11,6PSI now, noticeable difference! :)
- thedjjack
- Vehicle: 1989 L300 HITOP!!
My experience is black smoke = unburned fuel = HEAT... Watch EGT...
My fiends Cummins on extreme tuning makes lots of black smoke and 975 ft.lbs of torque but you have to watch the EGT as it goes extreme real quick....but fun fun fun...
ubernub
HMm! I dont have any EGT gauge, maybe i should turn the diesel pressure down again? what could happen if the exhaust gas temp gets too high? broken turbo? the engine temp gauge in the car is always on bottom of the "OK running temp line" when its fully heated.thedjjack wrote:My experience is black smoke = unburned fuel = HEAT... Watch EGT...
What could happen if i ran too lean? (too little diesel)
ubernub
- thedjjack
too much exhaust heat will blow the motor...crack head, melt valves, melt pistons, melt turbo....
Extreme exhaust temperature will not show up in water temperature as the motor will melt prior to water getting too hot.
EGT/Pyro are repetitively cheap..
You can go as lean as you want eventually it will not run....and only get colder and colder (it is opposite world to gasoline engines)...
- jwfchase
- Vehicle: '92 Super Exceed
I've always wanted to try upping my boost, but not until there's a pyrometer onboard...
Is your exhaust system stock or have you gone to a 2"- 2 1/2"?
ubernub
[quote]
Is your exhaust system stock or have you gone to a 2"- 2 1/2"?[/quote]
Its stock.
Its stock.
