Trouble lights
Carp
- Vehicle: 94' L-400 Super Exceed
Trouble lights
I could use a bit of advice regarding my dash trouble lights. A few weeks ago three bulbs started glowing faintly at the same time. They were the "water in fuel pump" the "battery" and the "A/T" light. two are side by side so I thought perhaps the light was just bleeding through. Anyway, instead of glowing faintly, they are on solid now. I have drained the fuel pump and have checked the tranny fluid and the battery is charging just fine so I am out of ideas., Anyone?
Carp
Re: Trouble lights
The charging system seems to be working great so I believe that indicates a healthy alternator.
Re: Trouble lights
If those three lights are on when the engine is running, you have a problem with the charging system.
madmazda
- Vehicle: 1994 l400
Re: Trouble lights
mararmeisto wrote:If those three lights are on when the engine is running, you have a problem with the charging system.
X2
Re: Trouble lights
x3
it may just be a loose connection or fuse
- thedjjack
- Vehicle: 1989 L300 HITOP!!
Re: Trouble lights
alternator X4
Check the wire on the back and the battery terminals first...
Mine was flashing the lights on start up and once and a while...never had a starting issue both batteries are 12.5V with motor off. Start truck and 12.3V is all the alternator could put out.
just had it rebuilt $224.00 including the oil seal for the vacuum pump L300. Installed myself.
Now it puts out 14V at fast idle as it should.
Carp
Re: Trouble lights
Thanks to all for your assistance. I have an alternator being shipped to me and I hope to be back on the road by the weekend, thanks to Mardy as well.
legionnair
- Vehicle: delica L300
Re: Trouble lights
Are you getting your alternator from Rising sun imports? If so it is a good replacement but before warned the stock connector is not the same. If you pick up a 2 pin weather pack both ends and install the connector before installing the alternator you will save yourself some grief.Carp wrote:Thanks to all for your assistance. I have an alternator being shipped to me and I hope to be back on the road by the weekend, thanks to Mardy as well.
Good luck
Dustin
