Transmission (tranny) Oil Cooler Replacement
Details Monster
Vehicle: Delica L400
Post by Details Monster »
About 2 weeks ago my transmission oil cooler developed a corrosion hole and spewed fluid all over. I could not find a direct replacement and did not want to chance a used one. Here is a link to what I found on eBay (http://www.ebay.ca/itm/330593242790?ssP ... 1439.l2649) which was almost a 100% match of the original and just required some creative mounting (see attached pictures).
Final Installation
Final Installation
legionnair
Vehicle: delica L300
Re: Transmission (tranny) Oil Cooler Replacement
Post by legionnair »
Nice find
nxski
Post by nxski »
Were you able to raise it up further as well when you were mounting it?
Details Monster
Due to the changed mounting for the new cooler, it now sits about 1 inch higher above the 'shield' which should protect it a little more from small rocks. If one wanted the back end could be tilted up further as there is quite a bit of space on the back side (there is nothing on the front). Not sure you would want to do that as it would affect cooling. For serious off-roading one would want to relocate it completely.
north54
Vehicle: 1989 P35W
Post by north54 »
Nice post Details Monster! Looks like I'm about to do this as my cooler is corroding away. Luckily the ebay seller still sells these.
Where did you get the brass fittings and hose if you don't mind me asking?
TRUSTY RUSTY
