Where is coolant drain plug located?
Sean
Coolant drain plug
Spadelica
- Vehicle: 1994 L400 SuperExceed
- Rising Sun Auto Import
Re: Coolant drain plug
Just near lower radiator hose.Spadelica wrote:Where is coolant drain plug located?
Sean
You need to take off cover to reach.
- 20110910 071.JPG (173.74 KiB) Viewed 3329 times
Spadelica
Thanks, it is the first one I removed, then separator plug and radiator cap. I was following the manual saying forth step is remove drain plug from cyclinder block to drain engine coolant, it is the one i still looking for.
Sean
Sean
Manitoba deli
It's under the injection pump, just in front of the starter. Difficult to see without a flexible mirror, even harder to reach without removing the starter.
Jason
Jason
Spadelica
No luck, I unable to locate the drain plug. My motor have AC compressor removed (magetnic clutch was damaged) and should be easy to spot without of taking starter off. Do anybody have any photo or diagram of motor where drain plug is? Or don't 4M40 have cylinder block drain plug?
Sean
Sean
Spadelica
I have found it, it is under turbo on other side.
Sean
Sean
