what should be noticed before or after using 4m40 engine?
GENTLE WOLF
- Vehicle: DELICA L400
i m a newer of diesel engine, pls tell what should be noticed when using the L400.where to change the oil and filter more cheap in vancouver.thanks
thelazygreenfox
Re: what should be noticed before or after using 4m40 engine
GW "search" all the topics you want info on. It's probably been discussed before and available by searching the site.
TLGF
TLGF
- thedjjack
- Vehicle: 1989 L300 HITOP!!
Go to CVI in Richmond the know the motor and will use correct filters oil. You do not want to save $$$ using low quality stuff diesels oils is everything.
Do not drive it like a gas motor if pushing the "gas" pedal down does not make it go faster...do not push it more it will just make heat and can damage a diesel motor.
GENTLE WOLF
thanks a lot , by the way ,where is the CVI?GENTLE WOLF wrote:i m a newer of diesel engine, pls tell what should be noticed when using the L400.where to change the oil and filter more cheap in vancouver.thanks
- Profister
This thread is unreal; this is what I meant talking about the forum degradation...
Profister wrote:This thread is unreal; this is what I meant talking about the forum degradation...
EDIT:mark wrote:http://WWW.DELICA.CA is a forum with only ONE posting rule...
Rule 1.1.1 -- Positive Contribution Rule
...However, when responding to a post that you disagree with, always clearly specify which points you disagree with, and always supply your reason for disagreeing. Correct any inaccuracies, but do so in a respectful manner that shows that you understand that the inaccuracies were posted in good faith...http://www.delica.ca.
CVI is a mechanics shop in Richmond. Please make use of the search function on here, it is meant to help cut down on the amount of repetitive posts on this site. Welcome to the world of Delica!
- Profister
I am telling you, this is an unreal thread. What is next?
By the way CVI Auto is HERE
I was searching for "unreal because..."Profister wrote:I am telling you, this is an unreal thread. What is next?
mac_stang
- Vehicle: 94' L400
To good to answer questions...you guys are "UNREAL"
Not all owners share the same half ass, speculative knowledge you clowns think you have.
I just lost all respect I had for you "long time" members.
...unbelievable.
Brad
...unbelievable.
Brad
- Mr. Flibble
The so called "degradation" of forums happens when a topic becomes more mainstream and more people seeking the given information join the crowd. Yes, people ask the same questions as have been asked before, but if we encourage them, and help them with answers - both by posting links and by offering answers (even if they are in the FAQ) we will make for a better community.
GENTLE WOLF, welcome!
bassnailer
I smell a Troll
