Removing road tar from vehicle
- CREGAN
Re: Removing road tar from vehicle
That looks amazing! Excellent job. I love it when anotha brotha helps out. Ian- if you are bored and feel like a road trip I got some paint that needs restoring and something tells me I am doing it the hard way. I can pay in beer.....
Craig
Craig
Leduc? That's like, in a whole other province, isn't it?CREGAN wrote:That looks amazing! Excellent job. I love it when anotha brotha helps out. Ian- if you are bored and feel like a road trip I got some paint that needs restoring and something tells me I am doing it the hard way. I can pay in beer.....
Craig
I jest. That would be a good road trip though.
- Aciled
- Vehicle: 94 L400 SE SWB
Craig
If you or someone can manage a high speed buffer, I would gladly send you some product for the cutting part. I use PRO products and 3M.
For Jesse's cut I made a 'Special Cocktail' using 60% http://www.prowax.com/bodyshop/P-27-Q_U ... mover.html and 40% http://www.prowax.com/polishes_glazes/P ... ooter.html
I used a wool pad to do the initial cut and then switched over to foam pads. Be careful if you have not used a wool pad before you could easily burn paint.
I finished it off with four thinly applied (with an Orbital) of http://www.prowax.com/paint_sealants/P- ... alant.html
As for the final product a wax you could get is a can of Meguire's Carnuba paste wax .... Make sure it is just a wax. 100% is the best.
Next week I will apply a half dozen or so thin layers of http://www.prowax.com/waxes/W-41_Yellow_Wax_Paste.html
The next time Mr. TAR decides to latch on, he'll slip off much easier...
What colour is your Deli ?
Ian
No wonder Jesse couldn't get that road tar off - he was only using one product at a time!
hardy har har
Luisito
- Member's Photo Album: http://virilesoulcreations.weebly.com/moon-unit.ht
- Vehicle: L300 High Roof
Nice work guys - both the results and how you did it!
Sanluis ph
- Vehicle: L400 Delica
I worked at an asphalt plant for 4 months, and had fine spray of tar all over my car one day. We used baby oil to clean the stuff off our hands every day, and worked great on cleaning my car as well.
Cool. Did you mix that with elbow grease or just use it neat?Sanluis ph wrote:I worked at an asphalt plant for 4 months, and had fine spray of tar all over my car one day. We used baby oil to clean the stuff off our hands every day, and worked great on cleaning my car as well.
He did a bang up job. The charcoal grey is a different shade and sheen than when I saw the rig for the first time.Luisito wrote:Nice work guys - both the results and how you did it!
Wildtrak
- Vehicle: 1989 Delica L300 4D56T
Hi!
A 10-1 mixture of water and kerosene will be a good way of removing road tar from your vehicle's body.
It is gentle on paint and hands and not expensive.
Glad to be of help
Wildtrak
Glad to be of help
Wildtrak
pajerry
I really can't believe the difference! I thought you were a teacher, not a car detailer!? How much for a full service and lesson? :)
