1996 L400 Jasper High Roof_SOLD
- Rising Sun Auto Import
High Roof, Grade 3.5, 135K
8 Seaters (Middle Row Bench Seat), Chrome Bush Guard, Chrome Side Steps, Original Alloy Rims, Skid Plate, Air Conditioning, Power Steering, Tinted Windows, and More.
price ; $11,400
Will be in Canada at July15.
We are accepting hold deposit. Ask for details.
Here are lists we check/replace for our stock delicas.
1. Engine componenets
** IP front seal replacement, valve adjustment, timing chain tension/loose adjustment, make sure no oil leaks( in case of L300, new timing belt/balancer belt/tensioners, 4 front oil seals replaced )
2. Transmission/4WD fuction
** If anything wrong, we replace sensor/switch, etc
3. steering/suspension/axle
** repack hub, and replace bearing if worn, all bushings/ball joints/CV boots/rack & pinion boot /links replaced if needed, wheel alignment, etc.
4. brake system
** flushing fluids, rotor machined or replaced, replace brake pads under 60% depth, all caliper checked
5. cooling system
** new radiator, new water pump, new thermostat, new hoses, new expansion bottle if needed.
** new temp guage/switch if needed
6. starting
** new battery if needed, new Hyundai 11V glow plugs ( best in Canada ), check glow plug relay/wiring, alternator/starter checked, make sure initial idle good.
7. interior
** make sure no broken parts, all power groups are working
8. exterior
** We focus on importing clean/good shape cars, no worry.
9. all fluids replaced ( engine oil, coolant, transmission oil, transfer case oil, front/rear differential oil ), new air filter/new fuel filter,all new V-belt, a/c checked and refilled.
10. compliance
** new tires Yokohama Geolandar A/T-S ( upgrade available with extra cost ), new e-coded headlight, DRL, marker/reflectors
11. canadian version CD player/stereo
** it is not included in our listing price.
12. block heater, trailer hitch
** installation extra
We might have missed some lists we usually do , but we are very proud of our job.
We have 7 Delicas this month.
For more in transit delica info, visit our website.
http://www.rs-import.ca/shop/step_subma ... 0723014349
Steven 778-995-2459
David 778-237-4602
** good/clean Delicas with affordable price/perfect maintenance into Canada**
price ; $11,400
4. brake system
5. cooling system
6. starting
7. interior
8. exterior
10. compliance
Steven 778-995-2459
David 778-237-4602
- 60274_169_orig.jpg (102.81 KiB) Viewed 8170 times
- 60274_171_orig.jpg (96.58 KiB) Viewed 8170 times
- 60274_I_orig.jpg (117.59 KiB) Viewed 8170 times
- 60274_19_orig.jpg (97.46 KiB) Viewed 8170 times
- 60274_30_orig.jpg (140.04 KiB) Viewed 8170 times
- 60274_31_orig.jpg (113.49 KiB) Viewed 8170 times
- 60274_39_orig.jpg (94.37 KiB) Viewed 8170 times
Last edited by Rising Sun Auto Import on Fri Aug 26, 2011 2:54 pm, edited 7 times in total.
Re: 1996 L400 Jasper in Transit_HOLD
More pics.
- 60274_170_orig.jpg (112.35 KiB) Viewed 8168 times
- 60274_172_orig.jpg (93.91 KiB) Viewed 8168 times
- 60274_173_orig.jpg (68.42 KiB) Viewed 8168 times
- 60274_32_orig.jpg (105.06 KiB) Viewed 8168 times
Last edited by Rising Sun Auto Import on Sat Jul 09, 2011 4:16 pm, edited 1 time in total.
Re: 1996 L400 Jasper High Roof in Transit_HOLD
This week will be final for our huge sales event ( HST included in sale price ).
Even if all our current stock are sold out, but we are expecting to pick up 6 Delicas this week from WWL.
Just not sure the exact pick up date at the moment because of not knowing when the strike end.
You still put a hold deposit until you finalize contract to take advantage of this sales event.
Your deposit will be fully refundable without any condition if you withdraw.
For more info, visit our website pls.
Steven & David 604-544-5120
Last edited by Rising Sun Auto Import on Thu Aug 04, 2011 9:39 pm, edited 1 time in total.
Paule
- Vehicle: 1997 L300 Active World
What's the "Auto Terminal" LCD tag all about?
Auto terminal Japan is a company that offers various services for both exporters and importers of Japanese used or pre-owned vehicles in Kobe, Nagoya and Tokyo bay.Paule wrote:What's the "Auto Terminal" LCD tag all about?
We are using their services for all in transit vehicles.
Number in the LCD indicates radiation level, introduced after Tohoku nuclear plant crisis.
Steven
Last edited by Rising Sun Auto Import on Thu Aug 04, 2011 9:41 pm, edited 1 time in total.
Seriously.......Rising Sun Auto Import wrote:.....Number in the LCD indicates radiation level, introduced after Tohoku nuclear plant crisis.![]()
Steven
Re: 1996 L400 Jasper High Roof_HOLD
This L400 Jasper , which has waited for release from WWL port since July15, is ON HOLD to Mark in Langley, BC.
Thanks for having business with us, Rising Sun Auto Import.
We are extending "NO HST Sale" event for quite some time.
http://www.delica.ca/forum/no-hst-summe ... 11213.html
Steven & David
604-544-5120
Steven & David
604-544-5120
- Artacoma
- Vehicle: 97 V6 LWB
Just curious what does the air terminal 0.99 picture mean?
Is that a grade of condition or something?
Rik
97 Series 2 V6 LWB
97 Series 2 V6 LWB
Artacoma wrote:Just curious what does the air terminal 0.99 picture mean?
FalcoColumbarius wrote:Seriously.......Rising Sun Auto Import wrote:.....Number in the LCD indicates radiation level, introduced after Tohoku nuclear plant crisis.![]()
Steven
Another radiation level indicator shown in our in-transit L300.
Steven
Steven
- P7260043.JPG (70.27 KiB) Viewed 7932 times
Re: 1996 L400 Jasper High Roof_SOLD
This L400 Jasper was sold today to Mark T in Langley, BC.
Thanks for your business with us.
5 more days for "NO HST Sale" event and we have 3 L400 and 1 L300 still on sale as Vancouver stock.
http://www.rs-import.ca/shop/step_subma ... 0722064611
We have another five units of L400 and four units of L300 in transit on Early Sep.
Detailed information will be posted later.
We beat any competitor's price/quality.
