Maintenance Light Reset?
davidb1551
- Vehicle: Mitsubishi Van
Hi everyone. You have a newbie here. I have owned my Mitsubishi Van for 20 years now and LOVE it. I need to know how to reset my maintenance light that is on the dash. I have always taken it to my dealer for service, but with the loss of a job and little income at the moment I need to do this myself. Any help would be greatly appreciated.
- snelson
- Vehicle: 92 Delica Exceed
Re: Maintenance Light Reset?
Hey david, can you describe the light- my L300 definiyely doesn't have a check engine light.
Is yours gas or diesel?
Its not the exclamation mark with a circle around it is it? That's your brake fluid light.
davidb1551
No it is not the exclamation with a circle. It is MAINT REQD written in red letters. This is also a 1990Mitsubishi Van/Wagon that was sold here in the states. The light is generally for large mile marks and the required maintenance need at such time.
Hi David, welcome to Delica Canada
Is it a gas engine? Do you know what engine designation it is?
davidb1551
Yes it is a gas engine and I believe it is a 2.4.
- R.Costa
- Vehicle: 1990 Mitsubishi Vanwagon
I have the same van and if you remove the 4 screws that hold the dash bezel on(2 in instrument view, 1 behind cover for the brake fluid res. and 1 behind rear wiper/hazard light switch), then remove the 4 screws retaining the instrument cluster(perimeter bolts), look on the back of the cluster behind the speedometer and you will see a black slide switch. slide the switch and the light will be reset. the factory service manual states to remove the maint. required bulb at 120,000 miles. hope this helps
davidb1551
R. Costa,
Thank you for the reply. I have had by dash apart many times to try and fix a speedo cable issue so this reset should be a snap. I just don't remember a black slide switch...but there again I wasn't looking for one at the time. Thank you so much. I will let you know the results. Hey by the way do you know where I could get a gear reduction for my speedo cable? It seems to be an obsolete part, other than a junk yard, and I don't want to purchase an old part that may fail again.
- CVI
- Member's Photo Album: http://cviauto.com
- Vehicle: 1994 Delica Space Gear Royal Exceed
Hi!
It could mean an engine fault code is present too. Big possibility it's an emission related problem. You can bring it to a basic garage and have them hook up a basic fault code reader to check what code came on...
Good luck,
Butch
Good luck,
Butch
- thedjjack
- Vehicle: 1989 L300 HITOP!!
I know on early Jeeps it was just a timer that went of after X-hours so that people would take the vehicle in for emissions check up (had nothing to do with anything...only a timer...I wonder if it was a US requirement pre standardized OBD2....
As your van is an American model, it should have an OBD connector somewhere under the dash into which the mechanic can connect to read the fault codes.
That being said, it's usually something emissions related (which if your van is running fine is relatively meaningless, especially for a vehicle 20+ years old), or it's a time/distance-based alert (as suggested by the other poster).
- R.Costa
An engine fault code would illuminate the CEL or "check engine light" the maintenance reminder light is for service intervals.
- R.Costa
The OBD connector is located just above the fuse panel.
