1996 Mitsubishi Supee Exceed L400 Delica Spacegear 2.8L intercooler turbo Diesel, 4m40 engine, Auto, 4x4, Super Exceed model, Winter package With Dual battery White color, L400, has 142,000 kms.
This L400 white color with wheel flair and a rear ladder is hard to find now a days
no rust under its been inspected on auction site
Has Crystal roof on this, Monrrof as well
Things will do to this lovely nice White L400 Crystal roof SWB
install brand new 4 tire Yokohama (ATS) all terrain tread pattern mud & snow,no charge for the cost of this.
install new Led day time running light, only take 2 watts on your battery energy,
we dont hook up direct to the headlight system thru
combination switch as soon will have big problem it will burn the complete headlight module, has full voltage,
not compatible hocking it up to the headlight switch System as its burns the combination switch.
install new block heater
4 new pro comp 9000 series shock heavy duty one
brand new front & rear brake pads= if needed
machine front & rear rotors = If needed
re-pack front hub both side if needed
new front stabilzer link if needed
new e-code headlight with led DRL headlight= new
New transmission Filter & fluids= new
new oil & all fluids,
new front & rear reflector
brand new L400 antifreeze water bottle original not china
new water pump
new thermosthat
All new fan belt 3 pcs
replace new front injection pump seal= no additional charge
Clean & pre set the 4 injector= no additional charge its included
New valve cover gasket
Do adjust TPS sensor timing to have a proper & smooth shifting of your L400 will runs like a car
will also install a newly conversion glow plug bas bar & cable to ensure to have a proper volts to each glow plug.
the old one or original one sometime dont give correct full voltage need the glow plug to heat it up when need to start this L400 when the weather is cold.
now it been tested to my other L400 & it works really good mostly when it in a cold early morning.
we try to improved the glow plug issue for this L400 when its reach a very cold weather & we prove it now that it works very good. its a big help when we install this.
thru us we only sell mostly fully service vehicle to give full customer satisfaction &
its a must to see before buying this type of delica for you & your family
we offer the best possible price for your budget with full service on this Delica
For your inquiry pls feel free to contact me, will more than happy to answer all your question.
This L400 comes with 1 year or 12,000 kms on power train warantty whichever comes first
Include one month full warranty including brakes, electrical, suspension and other issue that might occur
as this is a used car thru my shop in Richmond.
FULL COMPLETE WARRANTY WIHTOUT CHARGE WITH IN A MONTH OF YOUR PURCHASE THRU AMAZING AUTO IMPORTS LTD.
this is the kind of service we offer here for this car and all of the car we sell:
This lovely swb low roof will arrive next month JULY
Pls call
Stock # PE8W=142K White
Amazing Auto Imports LTD
DL# 30843
Any questions please call me:
604-247-2111 / 604-720-6144
thanks,
Sales Manager
96 Mitsubishi L400 SWB Diesel, Auto 142k =Call in Transit
- MardyDelica
- DSCN4082.JPG (84.69 KiB) Viewed 5196 times
- DSCN4084.JPG (86.24 KiB) Viewed 5196 times
- DSCN4085.JPG (85.43 KiB) Viewed 5196 times
- DSCN4086.JPG (82.94 KiB) Viewed 5196 times
- DSCN4091.JPG (77.56 KiB) Viewed 5196 times
- DSCN4094.JPG (73.18 KiB) Viewed 5196 times
- MardyDelica
Re: 96 Mitsubishi Delica L400 SWB Diesel, Auto 142 pls call
More pictures;
- DSCN4098.JPG (84.9 KiB) Viewed 5193 times
- DSCN4101.JPG (94.68 KiB) Viewed 5193 times
- DSCN4103.JPG (75.68 KiB) Viewed 5193 times
- DSCN4102.JPG (86.1 KiB) Viewed 5193 times
- DSCN4106.JPG (90.23 KiB) Viewed 5193 times
- DSCN4107.JPG (91.3 KiB) Viewed 5193 times
- MardyDelica
Re: 96 Mitsubishi Delica L400 SWB Diesel, Auto 142k pls call
More Pictures:
- DSCN4089.JPG (85.45 KiB) Viewed 5192 times
- DSCN4088.JPG (86.61 KiB) Viewed 5192 times
- DSCN4104.JPG (54.41 KiB) Viewed 5192 times
- DSCN4105.JPG (79.8 KiB) Viewed 5192 times
- DSCN4109.JPG (82.06 KiB) Viewed 5192 times
- DSCN4112.JPG (63.85 KiB) Viewed 5192 times
WhoGotTheFunk
- Vehicle: Hopefully a Delica
Re: 96 Mitsubishi Delica L400 SWB Diesel, Auto 142k $11,800
Nice looking deli. Does this one come with new tires as well?
I'll have to get in touch with you in the near future Mardy as I'll be looking for a Delica. I pretty much want one that looks exactly like this, with maybe a little less km's. Probably not until the new year though.
- MardyDelica
hi, yes my friend,
all my delica i sell has new tire yokohama geolander good quality and expensive
but it goes together with the sale of the car.
we put good quality tire not all season tire for all our delica so it value your car your purchase from us.
also the other tire is rim. it has the aluminum wheel on it.all same design.
just need to be fix for flat tire.
call me anytime when you need a nice delica for you.
thank you for your inquiry,
really appreciate it a lot
Cheers;
Cheers;
- MardyDelica
Re: 96 Mitsubishi L400 SWB Diesel, Auto 142k pls call
Update:
This White L400 is in Transit
Cheers;
Cheers;
