Lug nut / stud size?
I've done lots of searching but can't seem to find a straight answer on this. It looks like my l309 and my mightymax are 12x1.5. Would this be correct? The tire place I went to stripped 3 of my nuts and even broke off the tip of one stud.
gtexjunkie
- Vehicle: 92 Delica GLX (P25W) 5spd
Re: Lug nut size
http://www.delica.ca/forum/lug-nut-size ... tml#p82305
Don't trust tire shops they will break your nuts
Also don't trust squirrels they will bite you nuts
Re: Lug nut size
Thanks, I managed to get it all sorted out. I definitely don't trust this tire shop anymore.
Re: Lug nut size
gtexjunkie wrote:Also don't trust squirrels they will bite you nuts
Lug nut / stud size
Well like I said, the lug nuts are sorted. Does anyone know the EXACT stud dimension though? I'm hoping to figure this out before taking everything apart. It just makes things easier. (the alternative being taking a sample stud into lordco)
Re: Lug nut / stud size
You want the EXACT dimension ?nxski wrote:Well like I said, the lug nuts are sorted. Does anyone know the EXACT stud dimension though? I'm hoping to figure this out before taking everything apart. It just makes things easier. (the alternative being taking a sample stud into lordco)
Goto any parts shop and ask for a
wheel stud.jfarsang wrote:12x1.5
Have a digital caliper at your ready and measure to your liking.
Re: Lug nut / stud size?
I went to Lordco to ask for that but they said I needed the length of the stud as well
Just asked CVI and they said 21mm. That's what I'll go with unless anyone would like to contradict this!?
