The Story:
During the removal and blanking of the EGR valve I noticed that the waste-gate actuator near the exhaust end of the turbo was broken. It's not missing the cotter pin, rather the cylinder/pin that is pressed into the exhaust actuator arm is sheared off.
The Confusion:
I know that I have been driving like this for quite some time... months, possibly close to a year, my side exhaust note has been different. There has been no noticeable change in power or fuel efficiency, or deathly-engine-doom from too much boost. All of which I find odd given how I understand turbos.
It's my *understanding* that this broken actuator means I have too much boost into the engine from the turbo. I've driven like this for a long time, hard at times, and I would assume that I should've blown something up in the engine by now. Could it be that when this fails, it fails safely? As in I'm NOT over boosting? Why is there no change in power either way?
The Solution?
The obvious way of fixing this is to remove the turbo and replace this waste-gate actuator arm with one that has a pin in it. Something that involves a lot of my time (OK) or nearly too much money (Not-so-OK). I would like come up with another idea if possible. Good, Bad or Ugly does not matter. Crazy and untested ideas are good too!
My first idea is to drill out the arm and get a free-floating bolt to connect the two. Next is to weld a new pin on.
For reference; I edited the picture below that was originally EricN's from this thread.
