94 Mitsubishi L400 SWB Low/rf Auto Diesel 39k SOLD
MardyDelica
Post by MardyDelica »
1994 L400 Delica Spacegear 2.8L intercooler turbo Diesel, 4m40 engine, Auto, 4x4, Exceed model, Winter package With Dual battery green color, L400, has 39,000 kms.
This L400 low mileage is hard to find now a days
Its a grade 3.5 which is good
no rust under its been inspected on auction site
Has dual Sunroof on it front and middle
has a complete curtain on it which is a plus
has rear ladder which is also a plus for this nice low roof L400
Things will do to this lovely nice Low roof swb
install brand new 4 tire Yokohama (ATS) all terrain tread pattern mud & snow
no charge for the cost of this.
we dont put cheap all season tire on all our L400 as its no good.
install new led day time running light, only take 2 watts on your battery energy,
we dont hook up direct to the headlight system thru
combination swtich as soon will have big problem it will burn the complete headlight module, has full voltage,
not compatible hocking it up to the headlight switch System as its burns the combination switch.
install new block heater
4 new pro comp 9000 series shock heavy duty one
brand new front & rear brake pads= if needed
machine front & rear rotors,
re-pack front hub both side if needed
new front stabilzer link if needed
new e-code headlight with led DRL headlight= new
New transmission Filter & fluids= new
new oil & all fluids,
new front & rear reflector
brand new L400 antifreeze water bottle original not china
new water pump
new thermosthat
All new fan belt 3 pcs
replace new front injection pump seal= no additional charge
Clean & pre set the 4 injector= no additional charge its included
New valve cover gasket
Do adjust TPS sensor timing to have a proper & smooth shifting of your L400 will runs like a car
will also install a newly conversion glow plug bas bar & cable to ensure to have a proper volts to each glow plug.
the old one or original one sometime dont give correct full voltage need the glow plug to heat it up when need to start this L400 when the weather is cold.
now it been tested to my other L400 & it works really good mostly when it in a cold early morning.
we try to improved the glow plug issue for this L400 when its reach a very cold weather & we prove it now that it works very good. its a big help when we install this.
so buyer beware. thru us we only sell mostly fully service vehicle to give full customer satisfaction &
its a must to see before buying this type of delica for you & your family
we offer the best possible price for your budget with full service on this Delica
For your inquiry pls feel free to contact me, will more than happy to answer all your question.
This L400 comes with 1 year or 12,000 kms on power train warantty whichever comes first
Include one month full warranty including brakes, electrical, suspension and other issue that might occur
as this is a used car.only thru my shop in Richmond.
IT WILL BE ONLY DO FULL COMPLETE WARRANTY WIHTOUT CHARGE WITH IN A MONTH OF YOUR PURCHASE THRU AMAZING AUTO IMPORTS LTD.
this is the kind of service we offer here for this car and all of the car we sell:
This lovely swb low roof will arrive next month JULY
SOLD
Stock # PD8W=39K Green
Amazing Auto Imports LTD
Any questions please call me:
604-247-2111 / 604-720-6144
thanks,
MardyDelica
Re: 94 Mitsubishi L400 SWB Low roof Auto Diesel 39k In Trans
more pictures:
MardyDelica
more pictures;
MardyDelica
This lovely Nice L400 low roof L400
will arrived in next month;
very rare to find a low mileage vehicle
as many in the market now with high mileage
we pick mostly the good one for most of the customer
cheers;
MardyDelica
Re: 94 Mitsubishi L400 SWB Low/rf Auto Diesel 39k InTransit-
Still for sale
hard to find a nice low mileage short wheel base L400
available now next month
Cheers;
MardyDelica
Re: 94 Mitsubishi L400 SWB Low/rf Auto Diesel 39k On HOld
This Nice Low mileage L400
is on HOLD to Vernon B.C. residence
thank you very much,
Cheers;
MardyDelica
Re: 94 Mitsubishi L400 SWB Low/rf Auto Diesel 39k in transit
in transit
thank you
MardyDelica
Re: 94 Mitsubishi L400 SWB Low/rf Auto Diesel 39k On HOLD
This L400 arrived and on HOLD for now
Cheers;
MardyDelica
Re: 94 Mitsubishi L400 SWB Low/rf Auto Diesel 39k SOLD
This nice Low mileage L400 low roof SWB
is sold to Phil of Vernon B.C.
THank you very much,
1994delicaman
Vehicle: KTM
Post by 1994delicaman »
I had a good chat with Phil on the day he bought the van in front mardy's shop. he is lucky to have got a L400 with only 39k's on it!
2006 smart car diesel CDI
2011 KTM 990 Adventure
2015 Mercedes GLK250 Bluetec
2018 KTM Superduke 1290 R
