What is this and what does it do?
nxski
Post by nxski »
I was washing and waxing my van and this piece came off. One end of it fell inside and I'm left with a cap. What exactly is this for, what is it supposed to be and can I buy a replacement somewhere?
It's in the centre of the bottom half of the rear tailgate.
Re: What is this and what does it do?
Where is it on your wagon?
nxski
Post by nxski »
Sorry, I guess that really isn't clear :-D
I've updated the original post
thedjjack
Vehicle: 1989 L300 HITOP!!
Post by thedjjack »
That is the clip that holds the whole Delica together...Same as a pin in a grenade!
Delica is worthless now. Give you $1.00 for the whole thing.
No idea.
nxski
Post by nxski »
haha, I guess I should seal it at the very least so the tailgate doesn't fill up with water :shock: It feels like plastic but it could just be a rubber plug that has hardened and broken over time.
Could you add another picture that is not so close, get some perspective to it.
nxski
Post by nxski »
I'm uploading one now. It's behind the license plate which is probably why no one knows what I'm talking about. My vans uninsured right now so I see these things :-D
Hang tight...
nxski
Post by nxski »
here...that was fast
what 2.jpg (76.01 KiB) Viewed 3720 times
Jordan
Vehicle: 89 low roof L300
Post by Jordan »
keeps your license plate from rattling around...?
nxski
Post by nxski »
Possibly, the string I had tied to it did that though. It's a hole into and opening within the tailgate so there's the other end of whatever this is inside the tailgate now and also probably some water from when I was washing it. Hopefully there are no electrics in there that I might fry.
It's a damper to stop the registration plate from rattling in the brackets. Should be easy to find a replacement.
P.S.: I just read Jordan's post, post posting. I concur with Jordan.
Super Exceeded
Vehicle: 1993 L300S
Post by Super Exceeded »
Actually I believe it's the hole that a power lead come through for the backlit license plate holders. I had one on my Deli. It'll be at the swap meet if anyone wants it..
nxski
Post by nxski »
If it will plug my hole I might try to get it at the swap meet. If not I'll just look for a rubber stopper somewhere. :-)
Super Exceeded
Vehicle: 1993 L300S
I'm sure a lot of us could find things to plug your hole..... :o
nxski
Post by nxski »
:oops:
