Rear pads
NoDelie
Vehicle: pajero exceed 1989
Rear pads
Post by NoDelie »
The parts i did order don't fit my 89. it will fit a 92 and up though. I am looking for the rear pads that look like this.Help i have about 20 000 ks left then out of co mish. But am i ??. I still can send my pads to Alberta brake and clutch in Edmonton to have new pads put on. Then i have to wait for the bus to go anywhere, until they come back from Edmonton . How long this takes i don't know. This is why i want a second set so i can send one and use one set. I need help very soon.
Mitsu in Calgary is no help even with part #s . They hate the RHD. And will not order or even look for the parts anymore. Thanks for the service. Mitsu Dealers. Love the product still.
this one is the set i need
rear pads FERODO Part # FDB1010.jpg (11.85 KiB) Viewed 4661 times
This is what i have in my hand and its no good will not fit
this one is a no fit DELPHI Part # LP954.jpg (10.28 KiB) Viewed 4661 times
Smile, your boss will wonder.
Re: Rear pads
Go in and tell them you have a 4 cylinder 1988 Mitsubishi Montero. These were sold in North America (Canada and US) so it's in their system.
You don't have to tell them it's RHD. It's the same vehicle except for the engine/steering wheel.
NoDelie
Re: Rear pads
Post by NoDelie »
Thanks for the info . I Just tried and found out the 87,88,89 Montero did not come with rear disc. Same as the Raider. Going to call Rocky Mountain Imports and get them from John. I know he has them but I am trying to find them at a lower price but not easy to find part. I can send my old ones to Edmonton brake and clutch to be re padded. But that means the ride is not a ride for one week. If you or anyone has an old set around i could use them and send them to be relined would be great. Thanks for all the help.
pajerry
Re: Rear pads
Post by pajerry »
From what I gather on other paj forums, only the JDM mitzu pajero's/strada's etc had the rear disks. Everywhere else got rear drums until the second gens.
Orionsbelt
Vehicle: '90 Pajero LWB 2.5 TDi
Re: Rear pads
Post by Orionsbelt »
Don't know if you've seen this site yet... 4x4 Wire They list some parts including Pajero diesels...
There's a few posts regarding front/rear pads, rotors, and caliper's. Including one that has the upgrade.
http://www.4x4wire.com/forums/showflat. ... age=0&vc=1
And a Canadian Pajero dedicated site...
http://www.jdm.net/pajero/viewtopic.php ... 3ce6323c86
I'm going to have to do this myself soon so I am a little curious...
Orion
NoDelie
Re: Rear pads
Post by NoDelie »
It turns out i have the older version of your newer rides so i cant use the 92 montero rear pads. the design changed in 90 11 yy mm. Sucks for me. Here is what i have found out for my rear pads .
Cross ref brand and #
AKEBONO A-200K
AKEBONO AN-200K
FBL AFP152
KASHIYAMA D6013
MITSUBISHI MB407390
MITSUBISHI MB858521
MITSUBISHI MR389570
NiBK PN3152
NISSAN AY060-MT001
NISSHINBO PF-3152
SUMITOMO SN757
TOYOTA V9118-M008
size
Length-1 107.9
Pcs In Set 4
Thickness-1 12.9
Width-1 40.5
Years
MITSUBISHI PAJERO / MONTERO 83.05~87.07 2000 L041GW,L046GW
MITSUBISHI PAJERO / MONTERO 87.08~88.08 2000 L041G,L041GV,L0
MITSUBISHI PAJERO / MONTERO 83.05~86.05 2300 L043GW,L048GW
MITSUBISHI PAJERO / MONTERO 86.05~87.07 2500 L044GW,L049GW
MITSUBISHI PAJERO / MONTERO 87.08~88.08 2500 L044GW,L049GW
MITSUBISHI PAJERO / MONTERO 88.09~90.12 2500 L144GW,L149GW
MITSUBISHI PAJERO / MONTERO 88.09~91.04 3000 L141GW,L146GW
Other #s Mitsubishi
MB389570
MB407390
MB858521
MZ690022
MZ690042
M304021A
even the Mitsu parts numbers i got with the pj wont work in finding them. Mitsu wont order or work with me on this.
Your 91 might have the 92 montero calipers. Have a look on http://www.rockauto.com/it might help you out.
This is the one i need
rear pads FERODO Part # FDB1010.jpg (11.85 KiB) Viewed 4597 times
Does not fit Used for the 92 and newer
this one is a no fit DELPHI Part # LP954.jpg (10.28 KiB) Viewed 4597 times
Re: Rear pads
Have you thought about the swapping out the rear calipers/pads to the newer one's ? They are cheap across the border at NAPA. $75 per side fully loaded.
mdrive
Re: Rear pads
Post by mdrive »
We have them for $78.00, there is no match in North America. To do rear conversion, it will be very expensive,. you will need the get a whole rear axel from the wrecker.
Return to “Pajero”
