Removal of interior to access crystal lite roof
I'm in the process of trying to repair the rust damage done by the cl roof set-up. I've done the removal and here are the pictures I took...
Next step is to sand / remove rust from inside and out, rust proof paint the interior, bondo, prime and hippo line the exterior and then put the interior back on. I'm still wondering however if I am to miss a spot of rust and then cover it with rust proof paint will the rust continue to spread or should the paint take care of that?
- 1.jpg (76.89 KiB) Viewed 7727 times
- 2.jpg (73.85 KiB) Viewed 7727 times
- 3.jpg (72.37 KiB) Viewed 7727 times
- 4.jpg (71.5 KiB) Viewed 7727 times
- 5.jpg (74.43 KiB) Viewed 7727 times
- 6.jpg (75.05 KiB) Viewed 7727 times
- 7.jpg (77.45 KiB) Viewed 7727 times
Re: Removal of interior to access crystal lite roof
some more...
- 8.jpg (52.69 KiB) Viewed 7726 times
- 9.jpg (74.11 KiB) Viewed 7726 times
- 10.jpg (76.04 KiB) Viewed 7726 times
- 11.jpg (75.4 KiB) Viewed 7726 times
- 12.jpg (76.97 KiB) Viewed 7726 times
- 13.jpg (75.64 KiB) Viewed 7726 times
- 14.jpg (75.96 KiB) Viewed 7726 times
and more...
- 15.jpg (75.61 KiB) Viewed 7725 times
- 16.jpg (74.19 KiB) Viewed 7725 times
- 17.jpg (76.97 KiB) Viewed 7725 times
- 18.jpg (74.87 KiB) Viewed 7725 times
- 19.jpg (76.04 KiB) Viewed 7725 times
- 20.jpg (76.91 KiB) Viewed 7725 times
- 21.jpg (74.88 KiB) Viewed 7725 times
still more...
- 22.jpg (75.39 KiB) Viewed 7725 times
- 23.jpg (72.71 KiB) Viewed 7725 times
- 24.jpg (77.33 KiB) Viewed 7725 times
- 25.jpg (77.22 KiB) Viewed 7725 times
- 26.jpg (75.12 KiB) Viewed 7725 times
- 27.jpg (74.29 KiB) Viewed 7725 times
- 28.jpg (73.33 KiB) Viewed 7725 times
itsa cornucopia of images...
- 29.jpg (73.56 KiB) Viewed 7725 times
- 30.jpg (75.09 KiB) Viewed 7725 times
- 31.jpg (73.08 KiB) Viewed 7725 times
- 32.jpg (76.28 KiB) Viewed 7725 times
- 33.jpg (73.88 KiB) Viewed 7725 times
- 34.jpg (75.22 KiB) Viewed 7725 times
- 35.jpg (76.69 KiB) Viewed 7725 times
last one... (for the removal)
- 36.jpg (76 KiB) Viewed 7725 times
Tips:
- make sure you unplug everything and move things that could potentially get in your way.
- keep a cellphone close in case you get stuck with the main light assembly on your head and need someone to help you
- use a ratchet instead of a screwdriver when possible so you don't strip the screws
- watch out for falling particles of rust, bugs and other debris
- fix your roof before problems start to arise and things will go much more smoothly
- watch how you swing metal objects around with so much glass nearby
- pay close attention to what you're doing and label everything
- use logic an common sense
- don't force anything
Heck of a job, isn't it ?
Removal was quite fast and easy and I was inside the whole time listening to music. Took me about 3-4 hours to get it all removed but should be faster if you know what you're doing. I'm a little concerned about being able to sand down all the rust from the inside and am hoping that if I miss a tiny bit here and there it won't be detrimental in the future. I get the feeling the worst it still to come.
- Vehicle: -
Wow, there are quite a few spots...Do you actually see any rust spots from outside already or is it still all inside?
Glad I don't have a CL anymore
I do have some bubbles on the outside. I'm glad it's not as bad as most of the parts vehicles I've seen though. I still love the cl roof and I bought it knowing it had rust so I really shouldn't complain.
- thedjjack
- Vehicle: 1989 L300 HITOP!!
Time for a high-top??
You made a mould of yours then ?thedjjack wrote:Time for a high-top??
- naterade
Thanks for posting this!
I have to get into the roof myself one of these days to repair one of the sunshade wires, this helps me understand the process a bit
Nate
Nate
- thedjjack
no mould, I do not see a market to sell them, not the time, space, or the skill to pull a mould (but before it is on I would loan it out for a week if someone wanted to pull a mould (I am out of the Province at the moment)).jfarsang wrote:You made a mould of yours then ?thedjjack wrote:Time for a high-top??
