L300 Stretch updates
thedjjack
Vehicle: 1989 L300 HITOP!!
Re: L300 Stretch updates
Post by thedjjack »
Vehicle: -
Post by fexlboi »
no comments 8-)
Super Exceeded
Vehicle: 1993 L300S
Post by Super Exceeded »
WOW
Kinda makes one feel a little, ehem... ~ inadequate?
nxski
Post by nxski »
Jfarsangs recent post made me wonder... Are you going to be putting an extra gas tank in your beast? I assume it will be a bit more thirsty than the average Delica and we can't go too far on a tank of gas as it is.
nxski wrote:Jfarsangs recent post made me wonder... Are you going to be putting an extra gas tank in your beast? I assume it will be a bit more thirsty than the average Delica and we can't go too far on a tank of gas as it is.
That's why I use diesel. I go farther.
nxski
Post by nxski »
Diesel is a gas / fuel but 'gasoline' is not the same as Diesel. Therefor when I go across the border and say I'm going for gas to shorten the conversation I would be correct despite the fact that some of the border guards like to quibble with me.
In any event, if we are to use exact terminology should we not say 'gasoline', 'petrol' or 'petrodiesel'? In my opinion gas is too general of a term and it is never clear what we're talking about. I could tell the border guard that I'm going to pick up 'gas' come back with a gas fuelled bomb and I would never have told a lie (however I do understand that it would still be illegal, this is just a hypothetical).
Super Exceeded
Vehicle: 1993 L300S
Yup, I plan to at the minimum double the gas/diesel capacity.
On another front, I just found out that the SAS will be easier than I thought, (now planning to do it myself) and the diesel mechanic should be looking at the truck (Rain permitting) tomorrow. So with a little luck we're back to tooling around in Stretch tomorrow.
username
Vehicle: 1991 super exceed
Post by username »
you could prolly make some cash renting that thing out to movie productions :-D
bassnailer
Vehicle: '92 L300 Super Duper Exceed
Post by bassnailer »
username wrote:you could prolly make some cash renting that thing out to movie productions :-D
...Delicas' Gone Wild 2011!
DelicaDJ
Vehicle: 1999 Pontiac Montana, no Deli yet..
Post by DelicaDJ »
It's a unique limobus, that's for sure! :-D
Daniel
Super Exceeded
Vehicle: 1993 L300S
Yipppppeeeeeeeeeeeeeeeee she's running. Can't seem to get water temp. any one know where that wire is?
thedjjack
Post by thedjjack »
Think it is in the head either at the front or side above the injector pump..
Should see the sensor screwed into the head with room for a single wire to plug in. (careful running a hot motor without the sensor hooked up as it will let the glow plugs run a cold cycle).
Good to hear it runs!!!!
Vehicle: -
Post by fexlboi »
http://www.delica.ca/forum/whats-this-10504.html
One plug is for the ECU and the other plug is for the water temp.
thedjjack
Post by thedjjack »
you have coolant in the head right? I would pull the sensor if not sure to make sure it is in coolant.
what was wrong with it after you got it running was it dirty injectors?
