L300 to Delica !!!
Lupus
Vehicle: L300 4x4 '97
L300 to Delica !!!
Post by Lupus »
How can I convert my L300 to Delica?
I tried to find the parts list book to find the parts nos but it is very hard to find them especialy digital.
I like very much the double headlights and i think that thiw model does not exist here. So, can enybody help me?
Thiw is I want to do...!
This I have...!!!
This I have...!!!
Luna-Sea
Re: L300 to Delica !!!
Post by Luna-Sea »
Have you thought about these?
Lnd Srk(Medium).jpg (62.59 KiB) Viewed 4441 times
They are in my opinion a lot better than the later style,
cheaper and looking at the lines might fit with less
modification.
8-) Right On!
Lupus
Post by Lupus »
Not bad.... where can I find these and what about cost?
I like more the first one but I think that it will take more work and parts. hood, corners, headlights etc.
Do you know where can I find a parts list in pdf ?
Yokohama
Post by Yokohama »
The 4-lamp type headlights are the standard ones for USA-spec L300's. They can be ordered from USA dealers.
You may need to make some modifications to mount alternate headlight mounting hardware.
I can get the part numbers if you need them.
Lupus
Post by Lupus »
Thanx
I think that there is not only the headlights but the hood, the cornrers, the headlights mounts inside, the plastic piece in the center etc. These are the parts I obviusly need but I dont Know if there is more. Maybe the parts list book solve the problem but I dont have it especialy in us specs.
If you can find the parts no it will help a lot
Thanx again
Yokohama
Post by Yokohama »
Since you need everything; these are the "headlamp kit" part numbers. They seem to include everything except the actual lamp unit. The front trim for the headlamps is part of the clearance lamps.
KITS: MB527637 and MB527638
Trim/clearance lamps: MB527509 and MB527510
Front panel: MB506642
If you want pricing and availability let me know.
Lupus
Post by Lupus »
Thanx a lot.!!!!
First I will ask the local dealer. Most possible is that he dont have these parts but asking has no cost.
Otherwise I must import them from US, so I let u know.
Do I need the corners or they are the same?
What about the headlamps mounts?
I think that is easier for u to find a parts book maybe in pdf. Can u tell where I can find one?
Thanx again
Yokohama
Post by Yokohama »
It appears that the front panel comes with the left and right body mounts for the headlamps. It also appears that the side corners that go above the lamps are the same for your model and the USA-spec L300, so you should be able to reuse your covers!
As to a catalog; ask your dealer if they can give you printouts of the screen shots of the areas that you are looking at. Most dealers are willing to do this.
