L300 Stretch updates
- Super Exceeded
- Vehicle: 1993 L300S
Re: L300 Stretch updates
Ready for fiberglass
- 0131111817a.jpg (96.73 KiB) Viewed 3984 times
- Super Exceeded
I now have my snorkle, THX Felix
So lets see I'm almost done.
All I have to do is
finish the engine
put solid axle in
install snorkle
reattach bush bars
install winch
install CB
Finish and install rear fin
get and attach ladder
seal off clamshell door
add hydrolic lifts
make step
and then we're done.
no wait,
There's still the entire F%$%#@ interior
will it ever end!!!!!!!
All I have to do is
finish the engine
put solid axle in
install snorkle
reattach bush bars
install winch
install CB
add hydrolic lifts
make step
no wait,
Last edited by Super Exceeded on Thu Feb 17, 2011 11:12 pm, edited 1 time in total.
Are you staying with the 4D56T or did you get something bigger?
And will you have this all done by the 27th?
Judging by your post on the event (I believe that was you) stretch won't be done in time.
How about the mid March meet? Any chance we'll see the two of you there?
- Super Exceeded
I am cautiously optimistic for the march meet.nxski wrote:Judging by your post on the event (I believe that was you) stretch won't be done in time.
- Super Exceeded
mararmeisto wrote:Are you staying with the 4D56T or did you get something bigger?
as for the power plant I'm going pretty big, but it will be a suprise and most likely a late summer mod!
Last edited by Super Exceeded on Thu Feb 17, 2011 11:34 pm, edited 1 time in total.
The wing looks great.
Will you be concerned about it breaking off via stone/bird or such while on the highway ?
- Super Exceeded
Nope currently fibre glassing it. Should be fine.jfarsang wrote:The wing looks great.Will you be concerned about it breaking off via stone/bird or such while on the highway ?
- thedjjack
- Vehicle: 1989 L300 HITOP!!
Do you need more practice I have a nice roof that needs to be reglassed together.Super Exceeded wrote:Nope currently fibre glassing it. Should be fine.
- Super Exceeded
Do you need more practice I have a nice roof that needs to be reglassed together.thedjjack wrote:Nope currently fibre glassing it. Should be fine.
Built a and flew couple full size fibre glass airplanes so i'm good. But if you need a hand lemme know.
- thedjjack
Seeing how they Flew and you are still alive I may take you up on that!Super Exceeded wrote:Built a and flew couple full size fibre glass airplanes so i'm good. But if you need a hand lemme know.
- Super Exceeded
Glassing almost done!
- 0217111445a.jpg (65.51 KiB) Viewed 3805 times
- 0217111440a.jpg (65.6 KiB) Viewed 3805 times
- Vehicle: -
I have an idea for you. Save your self from a lot of hassle with the engine swap and the front and rear solid axle and just put the Delica body on this baby: http://tinyurl.com/4a3cxbc
I found a game with a 6 wheeled monster... Will yours be able to do this?
http://www.miniclip.com/games/monster-t ... itro-2/en/
- Super Exceeded
fexlboi wrote:I have an idea for you. Save your self from a lot of hassle with the engine swap and the front and rear solid axle and just put the Delica body on this baby: http://tinyurl.com/4a3cxbc
I called these guys in the UK about buying their differential set up. They wanted 6500 pounds for it, I politely declined..
