Vote for Hitop VS Poptop - PHOTOS of new roof on Delica pg 5
Vote for POPTOP vs HITOP
POPTOP
14
42%
HITOP
19
58%
Total votes: 33
thedjjack
Vehicle: 1989 L300 HITOP!!
Re: Vote for Hitop VS Poptop
Post by thedjjack »
just pipe the oil onto the ground and add 55 drums of engine oil in the van. That way the motor always has fresh oil.
Plus it will help with dust control on dirt roads.
later skater
David
thedjjack
Post by thedjjack »
new roof is on....brought it home today (still few little things to do to make it fit)
It's a close fit :-D
Super Exceeded
Vehicle: 1993 L300S
Post by Super Exceeded »
Looking at it now, I think it would have been a whole lot easier (and a lot less work) to build from scratch.
what would be the difference/benefit of using fibreglass instead of aluminum/mixed top ?
I've seen some nice rooflines in the europe that are mixed materials.
thedjjack
Post by thedjjack »
I am going with this top because I feel it will be faster, cheaper, easier then building from scratch. Draw back is it in not tough as far as hitting objects.
Should be not to bad to fit....cut into quarters remove inches in each dimension, put a plywood strip on the inside of 2 joints hold it together with screws, test fit, adjust, glass back together on both sides (over the added plywood strips), paint. Cut van roof off (add two braces). Drop on top, screw on.
The roof weighs under 100lbs very light. It would be a great time to take a mold for producing these tops.
Super Exceeded
Vehicle: 1993 L300S
thedjjack wrote:Should be not to bad to fit....cut into quarters remove inches in each dimension, put a plywood strip on the inside of 2 joints hold it together with screws, test fit, adjust, glass back together on both sides (over the added plywood strips), paint. Cut van roof off (add two braces). Drop on top, screw on.
Well since you've put it that way, it will be really, really easy to do. :-D
Sounds like it can be done in a day ! :-D
thedjjack
Post by thedjjack »
Read a few posts where people drive up to the same style year van and cut their roof swap the hitop and drive away in under 2 hours.
It will take some time, but be easier then welding a second Delica on the back! :mrgreen:
Super Exceeded
Vehicle: 1993 L300S
thedjjack wrote:It will take some time, but be easier then welding a second Delica on the back! :mrgreen:
Ha ha ha Mr. Funny man!
Any progress ? :M
thedjjack
Post by thedjjack »
on hold till i get some shop time at a friends shop. soon
thedjjack wrote:It would be a great time to take a mold for producing these tops.
I've been thinking about taking Turtle's poptop to a boat shop and have them fab up a box mould. Of course that requires time. :-D
thedjjack
Post by thedjjack »
I was thinking we should pull a mold of the hightop once it is glassed back together....place your orders now... :-D
thedjjack
Post by thedjjack »
So thanks to Jay :-D and Sam :-D ...We managed to get a few hours on raising the roof.
We managed to take out 12" from the middle and shorten it 22.5". Cuts were measured form a middle line that was at times eye balled. Cuts made with a skill saw with a carbide blade (cut a few screws for fun).
Looks like we are close. Now moving onto some initial fibreglass and few official test fits.
More photos thanks to Sam and his iphone addiction: http://s902.photobucket.com/albums/ac22 ... ed%20roof/
Cutting:
Fitting:
Waiting for Glassing:
