Water heater
- Super Exceeded
- Vehicle: 1993 L300S
Water heater
Anyone have any experience with these?
http://www.helton.com.au/index.htm
- Vehicle: -
Re: Water heater
There are a lot of reviews for this type of shower on ExPo: http://www.expeditionportal.com
I also came across a quite interesting setup for a portable shower. Specially for all the gas lovers out there. The worlds first LP gas appliance to feature a combined mobile water heater and cooking facility http://www.campinglab.com/cocinaducha.html
madmazda
- Vehicle: 1994 l400
Re: Water heater
Super Exceeded wrote:Anyone have any experience with these?
I have not but since i'm a plumber by trade i'm building a larger version in a holding tank that heats the shower water via the engine coolant it's going to be removable and easy hook up and easy use..... just going through the design now....
- Vehicle: -
Re: Water heater
http://dinoevo.de/2011/01/hot-water-tank/madmazda wrote:i'm building a larger version in a holding tank that heats the shower water via the engine coolant
- elgena_nautic_juniorm.jpg (40 KiB) Viewed 4978 times
Re: Water heater
I use two 16 plate heat exchangers to have almost instant hot water via engine coolant. Each cost me $18 + shipping on ebay. $23 inline pump. $25 for shower head. $12 for fittings and $10 for hoses/clamps. Total cost was $128 for a complete hot water system that I can pull water from a creek or bucket.
psilosin
- Vehicle: L400
Re: Water heater
Sounds cool Jesse. Any build pics? How long do you have to have the engine running to produce enough heat to get the water warm enough for a shower?
Re: Water heater
Built it for my Jeep many moons ago and took it out when I sold the rig. Have it waiting to be transplanted into the Safari.
Similar to pics below
- shower1[1].jpg (115.33 KiB) Viewed 4858 times
- shower2[1].jpg (127.16 KiB) Viewed 4858 times
- shower3[1].jpg (125.43 KiB) Viewed 4858 times
- showerbox[1].jpg (123.39 KiB) Viewed 4858 times
- shower5[1].jpg (74.45 KiB) Viewed 4858 times
- shower4[1].jpg (119.86 KiB) Viewed 4858 times
- DelicaDJ
- Vehicle: 1999 Pontiac Montana, no Deli yet..
Re: Water heater
Cool! Er... Warm!
Daniel
Re: Water heater
Falco sitting beside water heater:
Einstein
- Vehicle: spacegear
Re: Water heater
Nice unit, i just purchased a portable shwer unit that runs on propane.. called campchef.......portable water heater, should be up and running in a few days for camping/washing the dog....did you use some sort of quick-connect fittings on the hoses? do the leak? that is a great set-up. but mine has to go in more than just my deli.. so motor power isnt in the cards for me.... Great job
Re: Water heater
These guys have good gear/portable hot water systems and they are used extensively in the overlanding community
http://www.zodi.com/
For $160 their system is simple and turnkey/portable making it versatile from vehicle to campsite.
http://www.zodi.com/Consumer/zodihottap ... hower.html
Einstein
Re: Water heater
Hey, i just got an Ecotemp portable water heater, and it works great, added a 12v pump, and any source of water is instantly warm/hot(easy controls to set flow and temp)... and if you stay near a gardenhose you can gook it up to that too and all the hot water you could want... fitted mine into an old ammo case, and all accessories fit inside for easy and safe transport.. except the 10lb propane tank.will have to find a good spot for that. Will eventually rig up a shower curtin to a flexible tent pole that will hook onto a roof rack when i find the rite one.. might have to biuld the Rack cuse i wanna make my own rooftop tent... will post pics when the system is complete...
pajerry
Re: Water heater
I helped build something similar in the engine bay of a fj40 my step father had. It didn't have a the seperate pump though, we tucked everything neatly in the engine bay. I kind of like that Idea, probably crucial for a delica as there is not much room under the cab!
The only problem we ever had with the thing was that it would scald you if you weren't careful. Meanwhile in the summer you just bathe in lakes/creeks anyways so it didn't see as much use as you'd think. Sure is great to feel clean and civilized on a long fishing trip though
