Honey, have you seen my dashboard?
delica 304
- Vehicle: 1992 delica GLX
It all started innocently enough, I was looking to quiet a persistent squeak. I started twisting screws, and before I knew it,
- Um, honey...it fell off, honest!
- IMG_4312.JPG (104.78 KiB) Viewed 5949 times
- I stuck the speedo back on for laughs
- IMG_4313.JPG (102.2 KiB) Viewed 5949 times
- The front of the dash,
- IMG_4315.JPG (101.41 KiB) Viewed 5949 times
- Behold the mysterious and rarely seen dark side of the dash!
- IMG_4316.JPG (104.57 KiB) Viewed 5949 times
- thedjjack
- Vehicle: 1989 L300 HITOP!!
Re: Honey, have you seen my dashboard?
Thanks for the photos will be handy if I ever need to go in there?
I guess what is no longer in Delica can not make noise?
Lighter = Faster
Lighter = Faster
- konadog
- Vehicle: 1992 GLX L-300
Yikes! Hope you find that pesky dash cricket...
After I developed tinnitus a few years ago those little squeaks and rattles stopped bugging me so much. Hope there are a few other things you can do while you have yer bus apart like that! Thanks for posting - good to see you back here
delica 304
I was thinking of relocating the car alarm brain as it was poorly installed by Ralph's. I don't think that there will never be a better time!
- DelicaMark
- Vehicle: L400
Can't tell from the photos if those are stock front speakers but if they aren't you should think about changing them out if it is ever in your plans.
Fingers crossed that it all goes back in they way it came out and you don't get more squeaks!
How long did it take you?
Um, dude, you've gone waaaaaaaaayyyyyyyyyy beyond looking for a dash cricket!
What's going on?
What's going on?
- Super Exceeded
- Vehicle: 1993 L300S
Coming from someone who has taken things way apart, I already feel your pain putting it back together!!!
delica 304
I had previously changed the speakers... The hard way!
It was actually easier to remove the dash than it was to replace the passenger speaker! It only took me about 45 minutes to pull the dash, less if I knew before hand that I didn't need to unplug the switches in the dash. All the dash wiring is tied to the rest of the vehicle via quick connects.
An ulterior motive is to investigate relocating the stereo above the vents
Would you mind doing a photo essay on removal and replacement of the front console so we can post it up in FAQ? That would be tres cool if you could do that..... smiles. With some detail shots like where the screws are &c..
- thedjjack
You could have just filled it with expansion foam...just kidding!
