You know, now that I look at your vehicle, and what you've done with it, I got nothing.. no more ideas... nothing new... I pretty much like it the way it is.Super Exceeded wrote:Any chance you could kick in on some of the extra expense your idea cost me?almac wrote:i guess i'll take the blame for that...Super Exceeded wrote:good guess, but the idea actually came from a fellow Delica member*bows* i love it when 'vision' becomes reality.
nice job mang. i like it.
L300 Stretch updates
Re: L300 Stretch updates
- nvanadm
[/quote]
[/quote]
I'm sure the cheque is in the mail
- almac
why do you think i didnt do the mod myself?Super Exceeded wrote:Any chance you could kick in on some of the extra expense your idea cost me?
it's not like i put a gun to your head or anything...
al
al
- Super Exceeded
- Vehicle: 1993 L300S
If you look close they used the 2/5 ton military axles. These are needed as that is the smallest axles (that I know of) that allow a throughput for the second (most rear) axel.fexlboi wrote:Sweeet tires! The articulation is pretty impressive...thedjjack wrote:You have seen the Dodge Ram T-Rex 6X6 designs? http://www.fourwheeler.com/featuredvehi ... index.html
- thedjjack
- Vehicle: 1989 L300 HITOP!!
the competition:
http://www.4x4offroads.com/south-pole-e ... there.html
Looks like Sterling or Dana60 rear most axle...I have not found a shot of the power division to the back.
- Super Exceeded
I've seen their Yopu tube videos, cool truck for sure. There is a company in England that converts land rovers into 6x6's. The have coem up with their own dsign that bolts on to the front rear axle and with a PTO off of the drive shaft brings the power to the reatr axle. I called them butt he wanted 6000 Euros for it. NOT!thedjjack wrote:the competition:
- thedjjack
http://www.dieselpowermag.com/features/ ... index.html
Like this setup....you could use a standard divorced transfer case (need to look at oil up to top output though). Simple'ish
- Vehicle: -
How is it going with your engine swap?
- Super Exceeded
fexlboi wrote:How is it going with your engine swap?
Well, after making the mistake of asking for "opinions" I have come to the following conclusion. the Cantor engine was too expensive, as were serveral other newer engines that were also in the running. So here's what going to happen. I iwll fix the one I have and get it running. I will then take the block from my 1/2 deli and bore it. blueprint it and add a whole bunch of goodies to it to increase the power. As a wise deli owner said, fixing up a deli motor will allow you to just bolt it in when it's done. work starts next week!! i'll keep you all posted.
WIKI indicates up to 138 HP with direct injection. I'd like to see someone try this.
- 4D56.jpg (35.3 KiB) Viewed 7862 times
- Vehicle: -
Good luck with your transmission. If I remember correctly, GeryO had to rebuild his auto tranny a view times after he pimped the engine on his l300 with an intercooler and such...lrp374 wrote:WIKI indicates up to 138 HP with direct injection. I'd like to see someone try this.
- Super Exceeded
I have spoken to Gary about this. His suggestion was a new tranny. So that too is on my list. Most likely a toyota.fexlboi wrote:Good luck with your transmission. If I remember correctly, GeryO had to rebuild his auto tranny a view times after he pimped the engine on his l300 with an intercooler and such...lrp374 wrote:WIKI indicates up to 138 HP with direct injection. I'd like to see someone try this.
Jaz
Definitely intercool the beast with a good water to air intercooler if you haven't considered it - that'll open up the opportunity for a bit more boost and a few more ponies, plus with WTA you don't have to run 2" air piping to the front of the vehicle... just 1/4" flexible water piping :)
That combined with a snorkle and bored out goodness (have you considered sleeving it?) should provide for a longer lasting, reasonably "stock" engine.
Great build thread, looking forward to more updates and hopefully getting to see it before I leave for Australia!
- almac
i hope you have a lot of cash!
will be very pretty to look at, but expensive to run... hope its not going to be a daily driver...
al
al
- thedjjack
