Has anyone tried this yet? Is there a kit with seals and bearings, or whatever is needed? Mine is starting to leak a bit more oil and I would like to attend to it.
Thanks,
James
Turbo Rebuild?
docsavage
- Vehicle: Deliless...
Turbo Rebuild?
James
1989 Delica P24W Exceed
Panasonic CQ-TX5500W
- EnviroImports.com
Re: Turbo Rebuild?
Hi , is there play in the shaft? would you like it simply rebuilt, made stronger? larger? faster spool up/more air flow? many options for turbo repairs. Thats one of the things I have just started to get back into. I havent taken one off a delica yet, but if you can send me the model number and info I can get you a price for a full rebuild with warrantee.
ttyl
Noel
ttyl
Noel
docsavage
Re: Turbo Rebuild?
I would like to just rebuild it right now to fix the leaks. However, I could be easily convinced to tweak it a bit. I'll get the turbo model in a bit.
James
James
James
- EnviroImports.com
Re: Turbo Rebuild?
once you have the numbers I can get the price for you. do you want to rebuld it your self or have it done?
Noel
Noel
docsavage
Re: Turbo Rebuild?
Hey Noel,
The part number I found for my turbo is 49177-C. I will probably rebuild it myself as I need the vehicle, can only be down while I work on it.
Thanks for looking into this.
James
James
James
docsavage
Re: Turbo Rebuild?
I googled that part number, and except for the C it is a generic Mitsu Turbo. Stamped after the cast number was 510 which seems to be a 4D56 turbo.
James
James
James
- EnviroImports.com
Re: Turbo Rebuild?
would you like a price for a turbo re-build kit? I belive if you do it your self there is no warrantee with the parts, but ya its faster and cheaper so long as you know how to do it.
Noel
Noel
docsavage
Re: Turbo Rebuild?
Yes please, the kit price would be appreciated.
James
- EnviroImports.com
Re: Turbo Rebuild?
Hi James, are you able to take a pic of the tag that is riveted to the turbo, I need the numbers off that for the rebuild kit.
if you could either take a pic, or write them down and email that to me noel@enviroimports.com and I can get the price for you right away.
Noel
Noel
