I am a proud new owner of a L400 and am just starting
to do a few mods. First on the list was a new radio/sound system. I went out on my first weekend with my girl and we drove out and found a great spot about 30 k. off the pavement and set up camp. We had the stereo running and to make this long story shorter, we drained the battery. I figured if we waited till morning then I might get it started. I thought if I pulled the fuse for the daytime running lights it would help. Well of course, the fuse box diagram is Japanese. In the end some fellow in a Hilux happened by and gave us a boost. I would like to know which fuse is which though.
Fuse box
Carp
- Vehicle: 94' L-400 Super Exceed
- Profister
Re: Fuse box
I would recommend posting technical questions in the appropriate section and using SEARCH first.
- DelicaFuse1_resize.jpg (156.91 KiB) Viewed 2537 times
Re: Fuse box
This thread has been moved from General Discussion to L400 Technical.
Re: Fuse box
Don't you love delica.ca? "Welcome to the forum. POST IN THE RIGHT SECTION! LEARN TO USE THE OBTUSE SEARCH ENGINE! RAWR!"
Seriously, though, welcome to the forum.
Richard Dagenais
Carp
Re: Fuse box
yes, well thanks for the info and yes I will be very careful to research and post in the appropriate forum next time I seek some assistance.
Actually, this post was also meant as a form of introduction from me as I am new and this would be my first posting to the general collective of Delica fans. Thank you for your warm welcome, I feel warm and fuzzy now.
Re: Fuse box
Welcome to Delica Canada, Carp
We try to keep everything in the right forum so it can be referred to at a later date with the least amount of aggravation. The search engine is a weak link but it does work somewhat and will hopefully be upgraded before the end of the world. In the meantime if the site engine doesn't work for a particular search then try typing <+site:delica.ca and whatever it is you're looking for> into the Google search engine.
I remember the first post I made I got some guy out of Alberta telling me not to thread jack, which I had not intended but there you are... smiles. Get to know the forum index, there are a lot of coolios in this club forum. Also, where are you located? Get to know the "Events" forums ~ there is a mini meet at Ikea (Coq) this coming Friday (3 Dec) try to make it out, it'd be great to meet you.
