revs really high between shifts/delay on gas pedal release
LisaandTed
- Member's Photo Album: http://picasaweb.google.ca/116007411398370170745/D
- Vehicle: 91 Delica
Recently my gas pedal seems to have a delay in the release. I push in the pedal and it takes a few extra seconds to get back to its original position. I tightened up the cable which didnt really help. Has anyone come across this problem/have a solution?
Re: revs really high between shifts/delay on gas pedal release
Did it just start happening when it got cold out ?
LisaandTed
yup.
i was thinking it could be the housing contracting with the cold, but not sure
- thedjjack
- Vehicle: 1989 L300 HITOP!!
bad cable?
Try to rev the motor from the injector pump (I assume it is a diesel (it should not have a gas pedal
If the motor revs fine from the injector pump. bad throttle cable or needs lube or has water in it.
keep us posted
keep us posted
- thedjjack
also cable needs some play
LisaandTed
the problem is intermittent. when i rev it manuually it is fine. the cable releases slowly. probably build up/water in the housing.
LisaandTed
how do you lube it?
- thedjjack
take the cable out and run oil and graphite down it.
Personally I would replace it if you can get new. It is an important cable and maybe a sign of failure.
